Problem of NVRAM Size on Cisco7606-S
mhashemi1358
Dear Experts
We have  Cisco7606-S with two RSP720-3C-GE,When we install both RSP on the router,then the router show the NVRAM size at 2044K but when we boot the router with one RSP then the Size of NVRAM is Ok at 3096K,Please help me who we can solve this problem,Following please find the Show version in both Condition
Also I have attached the Boot procedure when the router boot with two RSP Card
Router#sh vers
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRC6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 08-Mar-10 10:39 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
Router uptime is 4 minutes
Uptime for this control processor is 4 minutes
System returned to ROM by  power cycle (SP by power on)
System image file is "bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRC6.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606-S (M8500) processor (revision 1.1) with 851968K/65536K bytes of memory.
Processor board ID FOX1623G5WV
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.1, (0x80390021)
CORE: E500, Version: 2.2, (0x80210022)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
52 Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
paolo bevilacqua
Already discussed in another thread, please do not post duplicates.
Excuseme,I have not found any discussion like my problem,can you please help me who have the same problem to find the solution,it is very urgent problem for us
Thank you so much for your cooperation
Actually you are not seeing a problem at all because the design itself is such by Cisco for some internal reasons.
So you need not be worried about that. If you need to check the actualy size of the NVRAM on the device (both Active & Standby RSP), kindly use the command "show file system". This would give you accurate results.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
