Problem updating firmware LTE module on ISR 4331
Jonnyballgame34
Hi, I'm trying to update the firmware on a New NIM-LTE-NA, and getting an error that doesn't make sense to me.   As far as I can tell I have the right command string, but it acts like it can't find the CWE file.  Output is below, (note, although I tried this example from USB, I get the same results with flash).  Thanks
10 drwx 16384 Apr 12 2011 01:38:58 -04:00 boot
11 -rwx 122 Apr 12 2011 01:38:58 -04:00 autorun.inf
12 -rwx 64381598 Oct 23 2017 05:51:24 -04:00 NIM-LTE_firmware.cwe
31249022976 bytes total (27834482688 bytes free)
USRICRTVP002#verify /md5 usb0:NIM-LTE_firmware.cwe
.........................................Done!
verify /md5 (usb0:NIM-LTE_firmware.cwe) = 55a85f5bea4f5b1b4abee2a399851ef6
USRICRTVP002#
USRICRTVP002#$eload cell 0 2 modem-provision usb0:NIM-LTE_firmware.cwe
Reload microcode? [confirm]
Log status of firmware download in router flash?[confirm]
Firmware download status will be logged in bootflash:fwlogfile
Microcode Reload Process launched for cwan slot/bay =0/2; hw type=0x102download option = 0
USRICRTVP002#
Requested file path is not a directory
*Oct 25 14:25:51.830: Microcode Reload Failed
have you tried the 'local' option:
microcode reload cellular 0 2 modem-provision NIM-LTE_firmware.cwe local
