problem with 2801
acazarkov
j have a problem with cisco route 2801 ,router simply blocking traffic , I can access via telnet (from outside address) but can't not ping interfeces or address in LAN .
when I restart it works a few days.
some of outputs:
F
astEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is ec44.7669.34a8 (bia ec44.7669.34a8)
Description: WAN
Internet address is 1111.1111.111.11/30
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
    reliability 255/255, txload 1/255, rxload 13/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:18, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:31:20
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 5178000 bits/sec, 440 packets/sec
5 minute output rate 595000 bits/sec, 229 packets/sec
    2878882 packets input, 3913500616 bytes
    Received 0 broadcasts (0 IP multicasts)
    0 runts, 0 giants, 1435* throttles
    20 input errors, 0 CRC, 0 frame, 3 overrun, 14 ignored
    0 watchdog
    1869570 packets output, 910697027 bytes, 0 underruns
    0 unknown protocol drops
    0 lost carrier, 0 no carrier
FastEthernet0/1 is up, line protocol is up
  Hardware is Gt96k FE, address is ec44.7669.34a9 (bia ec44.7669.34a9)
  Description: LAN
     reliability 255/255, txload 21/255, rxload 9/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:08:54
  5 minute input rate 3769000 bits/sec, 546 packets/sec
  5 minute output rate 8434000 bits/sec, 768 packets/sec
     300746 packets input, 229684059 bytes
     Received 655 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 3 throttles
     733 input errors, 5 CRC, 0 frame, 1 overrun, 1 ignored
     0 watchdog
     463102 packets output, 640893084 bytes, 0 underruns
     29 unknown protocol drops
Reply from 192.168.1.2: bytes=32 time=30ms TTL=126
Reply from 192.168.1.2: bytes=32 time=16ms TTL=126
Reply from 192.168.1.2: bytes=32 time=22ms TTL=126
Reply from 192.168.1.2: bytes=32 time=19ms TTL=126
Reply from 192.168.1.2: bytes=32 time=34ms TTL=126
Reply from 192.168.1.2: bytes=32 time=29ms TTL=126
Reply from 192.168.1.2: bytes=32 time=32ms TTL=126
Request timed out.
Reply from 192.168.1.2: bytes=32 time=39ms TTL=126
Reply from 192.168.110.2: bytes=32 time=14ms TTL=126
Request timed out.
Reply from 192.168.1.2: bytes=32 time=26ms TTL=126
Reply from 192.168.1.2: bytes=32 time=28ms TTL=126
Reply from 192.168.1.2: bytes=32 time=15ms TTL=126
Request timed out.
Reply from 192.168.1.2: bytes=32 time=55ms TTL=126
Reply from 192.168.1.2: bytes=32 time=27ms TTL=126
Reply from 192.168.1.2: bytes=32 time=20ms TTL=126
Reply from 192.168.1.2: bytes=32 time=21ms TTL=126
8 Replies 8
Which version are you running on the router? These problems disapear often after an update of the software.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version 15.1(
RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
System image file is "flash:c2801-advipservicesk9-mz.151-4.M2.bin"
Cisco 2801 (revision 7.0) with 360448K/32768K bytes of memory.
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 DSP, 16 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
126000K bytes of ATA CompactFlash (Read/Write)
15.1.4M5 is the most recent version. It's worth a try.
Check a log file for errors in router. Maybe this will help to investigate the reason.
http://www.cisco.com/en/US/docs/ios/12_4/release/notes/124MCAVS.html#wp185580
As Karsten advised, it's good idea to upgrade IOS.
Hope it will help.
Best regards,
Abzal
Rick Morris
Level 6
Level 6
One of the issues I have seen with these errors is a cable problem.  Have you tried replacing the cable?
I also found this link too that had a similar issue
https://supportforums.cisco.com/thread/1003090
I use optical cable for wan link and its rent over network provider , And UTP for LAN . Cable
seem to be okay.
You have a faulty circuit, complain to telco.
acazarkov
this is resault of comand :
show stacks
Minimum process stacks:
Free/Size   Name
10900/12000  MRIB IPv4 Init Process
10932/12000  MRIB IPv6 Init Process
4104/6000   EEM Shell Director
58432/60000  script background loader
4900/6000   Inspect Init Msg
4928/6000   SPAN Subsystem
1972/3000   config_verify
15316/24000  Init
58644/60000  EEM Auto Registration Proc
4808/6000   Auto Upgrade Startup Process
4684/6000   DIB error message
4916/6000   SASL MAIN
1992/3000   allegro libretto init
4948/6000   LICENSE AGENT DEFAULT
4920/6000   FLEX DSPRM boot download main
4748/6000   RADIUS INITCONFIG
8860/12000  TFTP Server
10900/12000  HTTP SSL PKI CERTIFICATE CREATE PROC
1920/3000   Rom Random Update Process
52140/60000  AFW_application_process
33652/36000  TCP Command
Interrupt level stacks:
Level    Called Unused/Size  Name
  1    78031301   5920/9000  Network interfaces
  2    39767540   8544/9000  DMA/Timer Interrupt
  3           0   9000/9000  PA Management Int Handler
  4        1666   8552/9000  Console MPSC
  5           0   9000/9000  External Interrupt
  7    37051621   8544/9000  NMI Interrupt Handler
Spurious interrupts: 79138
