problem with bvi interface on ASR 1004
Muhammed AKYUZ
I tried to use bvi interface on ASR 1004 but it wasnot successfull..
What should be the problem:
ASR learns mac address. but it does not ping the devices. But if i assign the same ip to phisical port, it works (PINGS..)
asr 1000 e ait bridging config guide da bulamadim.
bridge irb
bridge 1 route ip
bridge 1 protocol ieee
interface GigabitEthernet0/0/1
  description 6500-BACKBONE-1
  no ip address
  negotiation auto
  bridge-group 1
interface GigabitEthernet0/0/2
  description 6500-BACKBONE-2
  no ip address
  shutdown
  negotiation auto
  bridge-group 1
interface BVI1
  ip address 10.72.33.250 255.255.255.0
ASR-1004-79#sh spanning-tree
Bridge group 1
   Spanning tree enabled protocol ieee
   Root ID    Priority    32768
              Address     c89c.1dc7.d901
              This bridge is the root
              Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
   Bridge ID  Priority    32768
              Aging Time 300
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/0/1             Desg FWD 4         128.9    P2p R-L2GP
Gi0/0/2             Desg DWN 4         128.10   P2p
Reza Sharifi
Take a look at below interface config.  It is shutdown.  do a "no sh" and try again
  no ip address
  shutdown
  negotiation auto
  bridge-group 1
Reza
ı have tried with no sh state but it does not work..
asr 1000 series does not support bvi interfaces
tac responded to me like that
Late response I know but yesterday I was searching for the same problem... I could achieve this using BDI instead.
Spanning-Tree on Neighbour Switch(es) and default ARP timeout on ASR needs to be considered as a problem and sorted seperately.
|SW-1|    -----------  ____
       |                        | ASR |
|SW-2|    ------------|____|
interface BDI31
ip address 31.31.31.1 255.255.255.0
encapsulation dot1Q 31
interface BDI32
ip address 32.32.32.1 255.255.255.0
encapsulation dot1Q 32
interface BDI33
ip address 33.33.33.1 255.255.255.0
encapsulation dot1Q 33
interface BDI34
ip address 34.34.34.1 255.255.255.0
encapsulation dot1Q 34
interface BDI35
ip address 35.35.35.1 255.255.255.0
encapsulation dot1Q 35
interface GigabitEthernet0/2/3
no ip address
negotiation auto
service instance 1 ethernet
  encapsulation dot1q 31
  bridge-domain 31
service instance 2 ethernet
  encapsulation dot1q 32
  bridge-domain 32
service instance 3 ethernet
  encapsulation dot1q 33
  bridge-domain 33
service instance 4 ethernet
  encapsulation dot1q 34
  bridge-domain 34
service instance 5 ethernet
  encapsulation dot1q 35
  bridge-domain 35
interface GigabitEthernet0/2/4
no ip address
negotiation auto
  bridge-domain 31
  bridge-domain 32
  bridge-domain 33
  bridge-domain 34
  bridge-domain 35
Btw: "Backup interface" feature works much better for our case as we eleminate STP issues and enable "spanning-tree portfast trunk" on Switch Trunk Ports.
