Router selection 150 mbps WAN access speed
Vinayaka Raman
Hello Friends,
We have p2p link that interconnects our data centers and the bandwidth is 150 meg link..
In the current architecture, one end of the link is Nexus 7k (data center 1) and other end
is catalyst 65k (data center 2)..
We are planning to migrate this link to routers.
We planned to install 3945 router on both data center and move the p2p link to this
routers.
Below is the show version of the router. Please advise if this can support 150 meg
throughput. We will run QOS, EIGRP, SNMP, PBR and ACLs on this.
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9_NPE-M), Version 15.0(1)M4,
RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 21:48 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M8, RELEASE SOFTWARE (fc1)
APHUBCR1 uptime is 7 weeks, 5 days, 21 hours, 38 minutes
System restarted at 11:36:52 UTC Fri Feb 22 2013
System image file is "flash0:c3900-universalk9_npe-mz.SPA.150-1.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.1) with C3900-SPE150/K9 with 987136K/61440K
bytes of memory.
Processor board ID FGL150411Q9
3 Gigabit Ethernet interfaces
1 Subrate T3/E3 port
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE150/K9       FOC15013J94
Technology Package License Information for Module:'c3900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
uc            None          None          None
data          datak9        Permanent     datak9
Regards Vinayak
Leo Laohoo
If I was to play this "safe", 3945 might do but if I have funds, I'd think about investing in the 3945E or an ASR1002X.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Cisco recommends the 3945 for up to 150 Mbps of WAN bandwidth.
PS:
3925 100 Mbps
3925E 250 Mbps
3945E 350 Mbps
