problem with EHWIC-4G-LTE-G
hkitsch
I have a brand new C1921 with EHWIC-4G-LTE-G using Vodafone to build an internet connection.
First I did the setup like shown in the config guides and got the internet connection, but it was unstable.
Then I found some issues with the old LTE-card firmware in the supportforum.
Following that hint, I did an IOS upgrade to 15.2(4)M3 and the LTE-card update to Modem Firmware Version = SWI9200X_03.05.19.04.
Post-checks after the update were all fine.
After that, I reconfigured the router again meeting the config guides.
Establishing the internet connection, I get an IP address on the cellular profile, but it's not bount to the cellular interface.
sh cellular 0/0/0 profile
Profile password Encryption level: 7
Profile 1 = ACTIVE*
PDP Type = IPv4
PDP address = 10.25.124.59
Access Point Name (APN) =
Authentication = None
Username:
Password: 05
        Primary DNS address = 139.7.30.125
        Secondary DNS address = 139.7.30.126
* - Default profile
sh run int cellular 0/0/0
Building configuration...
Current configuration : 193 bytes
interface Cellular0/0/0
description vodafone 4G
ip address negotiated
encapsulation slip
no ip route-cache
dialer in-band
dialer string lte
dialer-group 1
async mode interactive
end
sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         192.168.0.1     YES NVRAM  down                  down
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
Cellular0/0/0              unassigned      YES NVRAM  up                    up
Cellular0/0/1              unassigned      YES unset  down                  down
Cellular0/0/2              unassigned      YES unset  down                  down
Cellular0/0/3              unassigned      YES unset  down                  down
Before the upgrade the IP-address was bound to the cellular0/0/0 interface and I was able to reach the internet.
Does anybody have an idea, if this is a bug or am I missing any config?
Thanks for any reply
Horst
hkitsch
Meanwhile I got response from the TAC.
There is already a bug-ID for this issue:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCug43453
