Problem with HWIC-1ADSL and Cisco Router 2901
Yunas
I have a problem with my new HWIC-1ADSL card and Router 2901 with ios "c2900-universalk9-mz.SPA.152-4.M5.bin",  I tried to update ADSL card firmware with variety version but unfortunately It didn't work.
Does anyone have any idea how can I fix this problem?
Here's some info from my hardware:
Output of show int atm 0/0/0
ATM0/0/0 is down, line protocol is down
  Hardware is HWIC-DSLSAR (with Alcatel ADSL Module), address is 6412.2530.e4c8 (bia 6412.2530.e4c8)
  MTU 4470 bytes, sub MTU 4470, BW 2048 Kbit/sec, DLY 250 usec,
     reliability 0/255, txload 1/255, rxload 1/255
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  23 maximum active VCs, 256 VCs per VP, 0 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input never, output never, output hang never
  Queueing strategy: Per VC Queueing
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
Output of show dsl int atm 0/0/0
ATM0/0/0
Alcatel 20190 chipset information
Line has not yet been activated.
Modem Status:    Down (DMTDSL_DO_OPEN)
DSL Mode:        Unknown
Interrupts:      318704 (0 spurious)
PHY Access Err:  0
Activations:     0
LED Status:      OFF
LED On Time:     0
LED Off Time:    0
Init FW:         init_AMR_4.0.018.bin
Operation FW:    AMR-E-4.0.018.bin
FW Source:       external
DSL: Training log buffer capability is not enabled
 Thank you in advance.
Leo Laohoo
Layer 1 problem.  You sure something is connected to the port?
Yeah, I've checked my line via a ADSL modem and the link came up correctly.
There isn't any error on the link, and ADSL line.
Not sure.  You may have a faulty HWIC-1ADSL then.  This other thing is showing you've got a Layer 1 problem.
So if you plug the line straight to your cable modem and it's good but it doesn't work here then it could be a hardware issue.
Post your config.
