Problem with load balancing on eigrp
ryszard.jaskola
Community Member
Hello.
I have 4 x 2Mb PVC links between router A (7206VXR) and router B (3660). I set load balancing on eigrp. On Router B, when i run show ip route (router a) i have 4 paths. But on Router A i have only 3 paths to router B.
What is wrong ?
Best Regards Rysiek
5 Replies 5
tekha
Level 8
Level 8
Do you have 3 or 4 routes om router A, when doing a "sh ip eigrp topo ", and only 3 routes when doing a sh ip route ?
Then it might be that you need to do this, on router A:
router eigrp
maximum-paths 4
Hope it solves the problem.
I would suggest that you look carefully at each of the interfaces involved and make sure that there is not one interface that specifies a bandwidth or a delay different from the others. If one interface were set up differently it would cause the symptoms that are described.
Another possibility might be a distribute list on one of the interfaces.
If you are still having problems with this I suggest that you post the interface configs and the routing protocol config from both routers.
Rick
Rick
I have this situation, but i have maximum-paths 4.
Try this command on both routers:
sh ip eigrp topo | inc Composite metric
Are the 4 metrics exatly the same, on router A?
If not, then there is your problem.
As Rburts writes, you probably have a different bandwidth or delay on one interface. Or, a little less likely, you are having trouble with a route-map.
I found that 1 paths have bandwidth value less from other. I changed it and now is OK.
Thanks for help
Best Regards
Rysiek
