Problem with NAT and internet access
an_ho
Hi everyone,
I am having some NAT problems with my C1111X-8P router. The network currently looks like this:
[ISP]
[EdgeRouter, internal: 10.0.0.1 external: dhcp] --- [other network: 192.168.1.0/24]
[Cisco C1111X-8P, g0/0/0: 10.0.0.100 via DHCP, vlan1 on all ports: 192.168.1.0/24]
[Lots of clients]
Now, all clients receive IP addresses from the 192.168.1.0/24 subnet - however, they can only sporadically access the internet. The NAT table is populated, but most of e.g. web access fails or takes forever to load.
Also, I have noted a lot of inconsistencies when using WebUI to configure the router. For example, when I activate NAT via GUI on g0/0/0 the router does not receive an IP address - but does immediately when NAT is disabled...
Please see below for an excerpt from my running-config:
version 17.2
service config
! Call-home is enabled by Smart-Licensing.
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 50000
hostname CiscoRouter
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone GMT 1 0
ip domain name localdomain.local
ip dhcp excluded-address 192.168.2.1 192.168.2.101
ip dhcp pool LAN
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8 8.8.4.4
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-4065224063
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4065224063
revocation-check none
rsakeypair TP-self-signed-4065224063
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
license udi pid C1111X-8P sn XXXXXX
memory free low-watermark processor 73242
diagnostic bootup level minimal
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
ip dhcp client client-id ascii [redacted]
ip address dhcp
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
ip access-list standard 1
10 permit 192.168.2.0 0.0.0.255
Any help is greatly appreciated!!
Best
Andrew
Hello
Have your clients point to the router itself for dns and then have the rtr forward dns queries also remove the default route pointing to the wan interface as it will create unnecessary arps lastly you can set mtu to avoid any fragmentation.
Example:
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
no ip dhcp client client-id ascii [redacted]
ip mtu 1492
ip tcp adjust-mss 1452
ip dhcp pool LAN
no dns-server 8.8.8.8 8.8.4.4
dns-server 192.169.2.1
Kind Regards
Paul
balaji.bandi
what is the edge router ?  is the users connected to edge router works as expected ?
as per the diagram your LAN IP address 192.168.1.0/24  (but your config 192.168.2.0/24 ? Please confirm?)
You need only 1 Route is good enough :
Looks for me MTU Issue here, since you said you able to get internet, and it was noticed ON and OFF ?
BB
try and set the MTU size to something like 1400:
ip address dhcp
ip nat outside
--> ip mtu 1400
negotiation auto
Hello
Example:
ip mtu 1492
ip dhcp pool LAN
Kind Regards
Paul
