Problem with VRRP MGMT second Gateway
mnice
hello guys,
I hope you're well.
I've set up VRRP on two C9500s, it works but I have a random problem accessing the second C9500, sometimes it's accessible, sometimes it's not.
Regards.
Yes svi config without vrrp
MHM
10 Replies 10
Access use real interface IP not VIP.
Try this and check
MHM
Hello MHM,
Thank you for your return.
For management I use the vla x interface, which is the default gateway and also the virtual interface for VRRP
So you're suggesting I create another vlan dedicated to MGMT? or use the chassis outofband?
SW01 :
interface Vlan X
description VLAN_ADMIN
ip address 192.168.1.1 255.255.255.0 ---- used for MGMT
vrrp 1 address-family ipv4
description VRRP group
priority 120
preempt delay minimum 60
address 192.168.1.1 primary
SW02:
interface Vlan X
ip address 192.168.1.2 255.255.255.0 ---- used for MGMT
priority 120
Regards.
Yes use vlan SVI detect for mgmt.
MHM
that's what I use the SVI interface, but it's in the VRRP.
Should I create a new SVI and not add it to VRRP to use it as MGMT ?
Regards.
MHM
OK bro I try and back to you.
Thx again.
Regards.
balaji.bandi
You need to provide some information, what IOS XE code running on both Cat 9500 ?how is this Cat 9500 connected each other (Hope they are not in SVL right ?)
 show vrrp config of both the devices
tell us from what IP address not reachable from what source IP address ?
BB
Hello Balaji,
1 - IOSXE = Version 17.03.05
2 - No SVL but VRRP
3 - The two devices are connected directly with two 40Gigabyte links
4 -  Show Vrrp SW01
show vrrp brief
Interface Grp A-F Pri Time Own Pre State Master addr/Group addr
VlX 1 IPv4 255 0 Y Y MASTER X.X.X.X(local) X.X.X.X
VlXX 1 IPv4 255 0 Y Y MASTER X.X.X.X(local) X.X.X.X
VlXXX 1 IPv4 255 0 Y Y MASTER X.X.X.X(local) X.X.X.X
4 - Show Vrrp SW02 (Not reachable)
5 - From LAN users (Another VLAN), but the address is sometimes reachable and sometimes not
Regards.
can you try ping 192.168.1.2 and try to connect.
how is these switches connected each other what port, where is your STP root bridge for the VLAN ?
where is users connectd ?
BB
When I try to ping it's not reachable and also when I connect with SSH (Random)
The inter-connection is made
STP is activated on SW01 (vlan 1-4094) root primary
on SW02 (vlan 1-4094) root secondary
Users are connected on access switches which terminates either on another access switch or on the last acces switch connected to VRRP switch depending on the location.
Regards.
