probleme with Static nat and Load balancing : DUAL ADSL
iliass joudat
Hi every body
i have a mysterious problem with static NAT and Load balancing outgoing
some one can help please ?
***********  the config .
Current configuration : 5258 bytes
! Last configuration change at 17:44:02 UTC Sun Oct 7 2012 by itsmaroc
! NVRAM config last updated at 10:35:19 UTC Fri Oct 5 2012
version 15.1
hostname ROUTER
boot-start-marker
boot-end-marker
no logging buffered
no logging console
enable password test
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.3.1
ip dhcp excluded-address 192.168.3.11 192.168.3.254
ip dhcp pool FIRE
import all
network 192.168.3.0 255.255.255.0
dns-server 212.217.0.1 212.217.1.1
default-router 192.168.3.1
ip name-server 212.217.0.1
ip name-server 212.217.1.1
crypto pki trustpoint TP-self-signed-1280271872
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1280271872
revocation-check none
rsakeypair TP-self-signed-1280271872
crypto pki certificate chain TP-self-signed-1280271872
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323830 32373138 3732301E 170D3132 31303033 32323439
  34385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
license udi pid CISCO1921/K9 sn FCZ16199053
license boot module c1900 technology-package securityk9
username test privilege 15 password 0 test
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.2 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
interface ATM0/1/0
no ip address
interface ATM0/1/0.1 point-to-point
pvc 8/35
  oam-pvc manage
  pppoe-client dial-pool-number 2
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname test
ppp chap password 0 test
ppp pap sent-username test password 0 test
interface Dialer2
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source static tcp 192.168.3.35 443 interface Dialer1 443
ip nat inside source static tcp 192.168.3.39 8080 interface Dialer1 8080
ip nat inside source static tcp 192.168.3.43 80 interface Dialer1 80
ip nat inside source static tcp 192.168.3.47 90 interface Dialer1 90
ip nat inside source static tcp 192.168.3.47 22 interface Dialer1 22
ip nat inside source route-map fixed-nat interface Dialer1 overload
ip nat inside source route-map fixed-nat2 interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 110 permit ip 192.168.3.0 0.0.0.255 any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map fixed-nat2 permit 10
match ip address 110
match interface Dialer2
route-map fixed-nat permit 10
match interface Dialer1
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
password test
login
transport input telnet ssh
scheduler allocate 20000 1000
end
paolo bevilacqua
On dialer interface, you should have "mtu 1492", not 'ip mtu', an 'no ip virtual-reassembly'
On g0/0, ip tcp mss-adjust 1452.
For the port-forwarding nat, you will have to use a route map also, selecting one interface only.
8 Replies 8
cadet alain
what is the mysterious problem exactly ?
Regards.
Alain
befor load balacing :
  • the router was fast
  • the NAT for SMTP exchnge awork correctely
hi alain
there is no solution for my problem ?
thinks
paolo bevilacqua
Thinks paolo for ur support ;
i never use before  port forwarding nat with route-map, can you give me an example ?
thinks
I have done what you asked me to do, but the proformance of the router are still low, but before the load balancing, it was good.
here is the new configuration :
ip dhcp pool FIRE
import all
  3082022.............
  quit
username itsmaroc privilege 15 iliass 0 iliass
no ip address
shutdown
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
pvc 8/35
interface ATM0/1/0
no ip address
pvc 8/35
  oam-pvc manage
interface Dialer1
ip mtu 1492
ip nat outside
no ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname iliass01
ppp chap password 0 iliass2012
ppp pap sent-username iliass01 password 0 iliass2012
interface Dialer2
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ppp chap hostname iliass02
ppp pap sent-username iliass02 password 0 iliass2012
ip http server
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
password itsmaroc
login
end
Sorry, I don't know what the reason could be. You can try updating IOS just a precaution.
ok thinks a lot Paolo
