Problems BGP load balance Route default
r-barbosa
i am with a question of how the bgp makes the load balancing, i have the environment as annex.
the output of the command "show ip route" does not appear the route of the second AS announced only one line appears below
R4#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 193.10.0.1 to network 0.0.0.0
191.10.0.0/24 is subnetted, 1 subnets
C 191.10.0.0 is directly connected, Serial1/1
C 193.10.0.0/24 is directly connected, Serial1/0
C 194.10.0.0/24 is directly connected, FastEthernet0/0
B* 0.0.0.0/0 [20/0] via 193.10.0.1, 00:55:33
R4#
the bgp does not offer the chance to take a load balance with AS different, I did the test with R2 and R3 in the same AS and worked, after re-configuration performed the command "show ip bgp" appear the 2 AS.
R4#show ip route
[20/0] via 191.10.0.1, 00:55:33
R4#
I am using dynamips with image for the 7200 router to simulate the environment will be some bug or some configuration of dynamips wrong. Below the configuration of each router
R2
interface Serial1/0
ip address 172.16.0.2 255.255.0.0
serial restart-delay 0
no clns route-cache
interface Serial1/1
ip address 193.10.0.1 255.255.255.0
clockrate 64000
no clns route-cache
router bgp 20
no synchronization
bgp log-neighbor-changes
neighbor 193.10.0.2 remote-as 40
neighbor 193.10.0.2 default-originate
neighbor 193.10.0.2 soft-reconfiguration inbound
no auto-summary
R3
interface Serial1/0
ip address 192.168.0.2 255.255.255.0
clockrate 64000
no clns route-cache
interface Serial1/1
ip address 191.10.0.1 255.255.255.0
no clns route-cache
router bgp 30
no synchronization
neighbor 191.10.0.2 remote-as 40
neighbor 191.10.0.2 default-originate
neighbor 191.10.0.2 soft-reconfiguration inbound
no auto-summary
R4
interface FastEthernet0/0
ip address 194.10.0.1 255.255.255.0
duplex half
no clns route-cache
interface Serial1/0
ip address 193.10.0.2 255.255.255.0
no clns route-cache
interface Serial1/1
ip address 191.10.0.2 255.255.255.0
clockrate 64000
no clns route-cache
router bgp 40
no synchronization
neighbor 191.10.0.1 remote-as 30
neighbor 193.10.0.1 remote-as 20
maximum-paths 2
no auto-summary
Also performed a series of commands from diagnosis as below.
R4#show ip bgp
BGP table version is 23, local router ID is 194.10.0.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
* 0.0.0.0 193.10.0.1 0 40 20 i
*> 191.10.0.1 0 40 30 i
R4#
If anyone has any hint of where to be incorrect already grateful, follow the following tutorial http://www.ccnalab.net/load_sharing_bgp.php
Sincerely
7 Replies 7
Joseph W. Doherty
You don't appear to have the AS prepends (on R4) as described in the lab note.
Sorry, is yes, just forgot to illustrate below
router bgp 40
neighbor 191.10.0.1 route-map prepend-as in
neighbor 193.10.0.1 route-map prepend-as in
neighbor 193.10.0.1 soft-reconfiguration inbound
maximum-paths 2
route-map prepend-as permit 10
set as-path prepend 40
Sincerely
That's looks good. Looking again at your original post, I see:
R4#show ip bgp
So, we see the prepend is applied to both R2 and R3, both default paths are in the BGP table, but it's picking the lower IP address path. I.e. it's acting like multipath isn't active. (I think I recall, BGP multipath shows up somewhere in the show ip bgp output, when active. If true, don't see it in your output.)
Try a "clear bgp *" on R4.
hi, already tried to the command "clear ip bgp asn", depending on who makes the router adjancency first this becomes the default route, which will be a bug in the simulator? You already had some environmental equal to this that I am trying to simulate?
Sincerely
"some environment", no not exactly, but I have used eBGP multipath in production environments; not using default routes, nor using the lab's own AS prepend technique, however.
An interesting point when i do shutdown in the serial R2 or R3, the other assumes the path to default route in R4
Sincerely
That would correspond with the fact that both paths for default are in your BGP table. Does the best path alway flip? I.e. if the best path is via R3, and you shutdown the serial to R3, does the best path remain with R2 after R3 is restored, or does if flip back to R3?
One thing you might try is advertise 10.0.0.0/8 from R1. See if it too appears twice in you BGP table, and whether as a multipath or just one path.
