Problems with a WIC1 on a 3600
diaz-jorge
I have a wic1 installed that i cant get to work.
when i do a sh ip int bri command it shows  its ip but under status it displays: reset. Does anyone know what reset status mean? also i dont' see it when i do a sh service-module command. That it mean that there's something physically wrong with it or i'm missing something?
3600 wic1 to T1.
thanks in advance..
wang baojun
hello  ,
can you paste some show command on , like show interface  show version ..
3600T1# sh ip int bri
Interface                  IP-Address      OK? Method      Status                     Protocol
FastEthernet0/0       unassigned      YES NVRAM       administratively      down down
Serial0/0                 unassigned      YES NVRAM       administratively         down down
Async2                   unassigned      YES NVRAM       down                       down
FastEthernet0/1       172.20.20.20    YES NVRAM       up                         up
Serial1/0:0                172.20.10.1     YES NVRAM       reset                      down
Ethernet2/0                unassigned      YES NVRAM       administratively      down down
TokenRing2/0
sh diag
WIC Slot 1:
        Single Port Modem WIC
        Hardware revision 1.0           Board revision H0
        Serial number     32335182      Part number    800-08823-01
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
        EEPROM contents (hex):
          0x20: 01 38 01 00 01 ED 65 4E 50 22 77 01 00 00 00 00
          0x30: 88 00 00 00 04 04 24 01 FF FF FF FF FF FF FF FF
Slot 1:
        CT1 (CSU) Port adapter, 1 port
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware revision 1.1           Board revision F0
        Serial number     27299702      Part number    800-01228-04
        FRU Part Number:  NM-1CT1-CSU=
          0x20: 01 26 01 01 01 A0 8F 76 50 04 CC 04 00 00 00 00
          0x30: 78 00 00 00 02 03 12 00 FF FF FF FF FF FF FF FF
It's not displayed under modules..
3600T1#sh service-module
Module type is 4-wire Switched 56
    Hardware revision is B, Software revision is 1.00,
    Image checksum is 0x42364436, Protocol revision is 1.0
Receiver has oos/oof, loss of signal,
Current line rate is 56 Kbits/sec
Last module self-test (done at startup): Passed
Last clearing of alarm counters 6d18h
    oos/oof               :    1, current duration 6d18h
    loss of signal        :    1, current duration 6d18h
    loss of frame         :    0,
    rate adaptation attemp:    0,
