09-08-2010 12:28 AM - edited 03-04-2019 09:41 AM
I have found "arp clear retry 1" command in 7606 configuration. What does this command mean? I couldn't find any explanation in reference guide. Software version is s72033-advipservicesk9_wan-mz.122-18.SXF9.bin.
09-08-2010 01:01 AM
It will clear the arp cache after 1 minute delay
09-08-2010 01:07 AM
Hello Vijay,
Thank you for reply!
Do I understand correct that arp cache will be cleared every 1 minute when this command is configured?
09-08-2010 01:35 AM
I didn't make my first post clear. This is a new implementation of the ARP cache clearing
After "clear arp", the arp/adj entries won't be immediately removed. ARP will send out arp request first, arp/adj entries will be refreshed if the arp response
is received. Otherwise, if ARP response is not received in a number of arp requests (configurable), the arp/adj entries will be deleted.
The command is
switch(config)#arp clear retry ?
<1-50> count
Default is 2.
09-08-2010 02:35 AM
Thank you for help!
