06-28-2013 03:17 AM - edited 03-04-2019 08:19 PM
Would like to know if the MPLS backhaul and Internet links can be placed on the same WAN router ie at the central HQ, the reason being the internet links are to be used as backup to the MPLS links aka DMVPN, any suggestions are most welcome.
06-28-2013 06:10 AM
Yes of course. What makes you think it would not work?
07-01-2013 01:46 AM
wanted to know what would be the good practice to follow viz;
1) Have the DMVPN access for the branch users through the Perimeter network (DMZ, FWs etc)
2) If the DMVPN is terminating through the common internet link, as above, would there be a performance related delay.
3) else, if a seperate Internet link for the DMVPN is procured and terminated on the same router as the MPLS links what could be the tradeoffs.
4) Are there such enterprises who have the internet and WAN links terminated on the same router?
06-28-2013 06:59 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Can the different links be placed on the same router, assuming the router supports the media, should be doable.
If the different links are intended to "backstop" each other, then the question becomes does the common device create a single point of failure. If it does, and you're concerned about statistical up-time, then you'll want to consider device diversity too.
07-01-2013 09:15 AM
In my company we use - internet router, wan router, dmvpn hub router[we run 100+ tunnels on 3825]
I would not do it in the same device.
