06-29-2023 04:53 AM
Hi Team,
I have above mention the scenario. My query is customer end provide 2 ISPs wan links, In case ISP-1 wan link is down. Now the ISP-1 public IP reach globally via ISP-2. Its possible or not, If possible means kindly explain the concept briefly.
06-29-2023 05:16 AM
You get defualt route from both ISP or many subnet ?
06-29-2023 10:00 PM
Yes sir.
06-30-2023 01:39 AM
Two ISP and one router learn defualt route via bgp
Use weight to prefer one path "ISP1" than "ISP2"
Command needs
Router bgp xx
Neighbor <isp1 ip> route-map MHM in
Route-map MHM permit 10
Set weight 40000
Note:- bgp prefer highest weightpath
06-29-2023 11:02 PM
if ISP subnets are publicly routable IP addresses (i.e public IPs), then you can reach one ISP subnet through another ISP in case of failure, it is normal internet design.
Of course, you should have default route (static or via BGP) towards ISPs or you should get partial / full routing table (this option requires more resources on customer side, so used when only real need exists).
06-30-2023 06:21 AM
Do you have your own AS with a public IP address block? Or, is your public IP address(es) provided by your ISPs? If the latter, do you have a (different) public IP address from each ISP?
