04-18-2020 04:33 PM
I have a newbie question for you.
I understand the "service password-encryption" is very weak but is there a more secure option for passwords?
Solved! Go to Solution.
04-18-2020 09:37 PM - edited 04-18-2020 09:37 PM
Use "secret" (5) instead of "password" (0/7) whenever possible.
username XXX password YYY
username XXX secret YYY
enable password XXX
enable secret YYY
Type-5 is hashing, which is non-revertible.
Type-7 is encryption/encoding, which revertible. (service password-encryption)
Type-0 is simply clear text.
However, not all password related command support type-5 encryption.
For example: tacacs-server key {0 string | 7 string | string}
So, be aware when you try to export the "show run" output and send to others. Examine any sensitive data even you have enabled "service password-encryption".
04-18-2020 11:58 PM
Using password gives you near to no security, and "secret" alone is not considered secure any more as it uses the very weak MD5 hashing. If your equipment is not completely outdated, the better way is to specify the algorithm as sha256 or script:
rtr(config)#username TEST algorithm-type ? md5 Encode the password using the MD5 algorithm scrypt Encode the password using the SCRYPT hashing algorithm sha256 Encode the password using the PBKDF2 hashing algorithm rtr(config)#username TEST algorithm-type scrypt ? secret Specify the secret for the user rtr(config)#username TEST algorithm-type scrypt secret ? LINE The UNENCRYPTED (cleartext) secret for the user
enable password XXX
enable secret YYY
04-18-2020 11:58 PM
