QoS and max-reserved-bandwidth
williamehmke1
I am having trouble finding a definitive answer and could use some guideance. Max-reserved-bandwidth command no longer exists so i'm trying to figure out how to overide standard 75% limit set by Cisco to possibly 80-85% and still leave 15%-20% for overhead
Below is how i want to define my policy map but i want to base it off utilizing 85% and not 75% (in this scenario i have a 1.544Mb circuit) - the numbers in red are the ones if I can increase max-reserved-bandwidth to 85%.
Any insight would be greatly appreciated
policy-map test
class voip
priority percent 25 (25% of 1.544Mb) = 386 kbps
class mission-critical
bandwidth remaining percent 40 (40% of 772kbps) = 308kbps - got this by 1.544*75%=1.158Mbps-.386kbps=772kbps
class interactive
bandwidth remaining percent 15 (15% of 772kbps) = 116kbps
class class-default
bandwidth remaining percent 45 (45% of 772Kbps) = 347kbps
policy-map test
class voip
bandwidth remaining percent 40 (40% of 926kbps) = 371kbps - got this by 1.544*85%=1.3124Mbps-.386kbps=926kbps
class interactive
bandwidth remaining percent 15 (15% of 926kbps) = 139kbps
class class-default
bandwidth remaining percent 45 (45% of 926Kbps) = 417kbps
25 Replies 25
Hello
Okay take the WAN policy:
policy-map BRANCH-WAN-OUT-Child
class VOIP
set ip precedence 5
priority percent 25
class ERP-WAN
set ip precedence 4
bandwidth percent 40
class Call-control-WAN
set ip precedence 3
bandwidth percent 15
class class-default
bandwidth remaining percent 100
policy-map BRANCH-WAN-OUT-Parent
class class-default
shape average 1312000 (85% of 1544)
service policy BRANCH-WAN-OUT-Child
int x/x
description WAN interface
service-policy out BRANCH-WAN-OUT-Parent
So now the wan interface is shaped at 85% of 1544mb and your child policy is using 100 of that cir
res
paul
Kind Regards
Paul
ok i see, so then my LAN policy which i have applied to my inside interface just goes away?
Also 1 final question, if i didn't want to use 85% of bandwidth but instead went with 99% would i still need that shape command?
Hello
Just change the shape value to acommodate your cir rate -
May i ask why just 99% and not 100%
res
Paul
Kind Regards
Paul
I thought i had to leave 1% for class class-default
Am I also correct when i say my policy-map BRANCH-LAN-OUT that is assigned to my inside interface goes away ????
finally this what my QoS will look like:
class VOIP
set ip precedence 5
priority percent 25
class ERP-WAN
set ip precedence 4
set ip precedence 3
class class-default
class class-default
shape average 1544000 (100% of 1544)
class VOIP
set ip precedence 5
priority percent 25
class ERP-WAN
set ip precedence 4
set ip precedence 3
class class-default
class class-default
Hello
"I thought i had to leave 1% for class class-default"  -<----- My understanding it does this by default
Usually I would mark on my Lan interface then classify this traffic on my WAN
One more thing maybe apply some fair queueing on the class-default  for some degree for fairness for this traffic, it not a necessity but I forgot to mention it.
class VOIP
set ip precedence 5
priority percent 25
class ERP-WAN
set ip precedence 4
set ip precedence 3
class class-default
fair queue
res
Paul
Kind Regards
Paul
thanks for all your help Paul
Paul, sorry for another question but i havent had much dealings with QoS. What do you mean when you say "mark on the LAN interface"
marx82
somebody here wrote that the max reserved bandwidth is gone but if I take an IOS released in 2019, just to make an example, it is still there.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_conmgt/configuration/xe-17/qos-conmgt-xe-17-book/qos-conmgt-oview.html
" The default maximum bandwidth is 75 percent of the total available bandwidth on the interface. The remaining 25 percent of bandwidth is used for overhead, including Layer 2 overhead, routing traffic, and best-effort traffic."
Yea, it does say that.  But is that documentation correct?  (Much changed with HQF CBWFQ  [BTW, overall, I consider post HQF CBWFQ a huge improvement, my only complaint with it was, upgrading an IOS to one using HQF CBWFQ. the same EXACT policy could behave differently.  For example, FQ in class-default, pre-HQF was WFQ, but in post-HQF it's just FQ, of course, over the years, Cisco also revised how WFQ computed its weight ratios too, so WFQ to FQ is just an extreme case of that - laugh.]).
On CML:
inserthostname-here>en
inserthostname-here#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
inserthostname-here(config)#class-map match-any test
inserthostname-here(config-cmap)#match any
inserthostname-here(config-cmap)#policy-map test
inserthostname-here(config-pmap)#class test
inserthostname-here(config-pmap-c)#bandwidth percent 100
inserthostname-here(config)#int g0/0
inserthostname-here(config-if)#service-policy output test
Insufficient bandwidth 1000000 kbps for the bandwidth percent (100%) guarantee
!This wasn't unexpected - HQF says class-default must always have at least 1%
!I recall (?) in pre-HQF, using max-reserved-bandwidth 100
!you could leave class-default with no bandwidth
inserthostname-here(config-if)#policy-map test
inserthostname-here(config-pmap-c)#bandwidth percent 99
inserthostname-here(config-pmap-c)#int g0/0
!No error, this time, and . . .
inserthostname-here#sh policy-map interface g0/0 output
 GigabitEthernet0/0
  Service-policy output: test
    Class-map: test (match-any)
      27 packets, 2762 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 27/2762
      bandwidth 99% (990000 kbps)
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
      (pkts output/bytes output) 0/0
!BTW, there's always a class-default, even if not explictly defined
!And, if you were wondering what the above's interface config looks like . . .
inserthostname-here#sh run | sec 0/0
interface GigabitEthernet0/0
 ip ospf network point-to-point
 ip ospf 10 area 10
 duplex auto
 speed auto
 media-type rj45
Possibly max-reserved-bandwidth still does something post HQF, or perhaps this is just a documentation error.  But, pre-HQF, just like the above 100% allocation, if you tried to not leave class-default with 25%, you would get an error.  Sometimes, depending on my CBWFQ policy, I did use to use a max-reserved-bandwidth, of 100%, so I could allow class-default less than 25%.
Since HQF, other than the 1% issue, seen above, I've never had to explicitly use max-reserved-bandwidth.
Anyway, I've given you a helpful bump because you're read the documentation, read these replies, and noted the discrepancy between them!
[edit - PS]
Being curious, I wondered what impact using max-reserved-bandwidth, might make, on the interface.
Tried it on my CML g0/0 interface, as above, it's an unknown command!
inserthostname-here(config-if)#m?
mac-address  media-proxy  media-type  metadata
mop          mpls         mtu
Thanks for your feedback. Very useful.
I tried to configure the reserved bandwidth as well and the option is not available.
