QOS & ATM on 7206vxr
tomredmond
I have setup "ip nbar protocol discovery" on the input interfaces, I have set up Class-map's and I have created the Policy-maps but when I apply them to the WAN (ATM sub-interface) I get the message "GTS : Not supported on this interface"
How do I get the WAN interface to shape traffic ?
The interface hardware is PA-A3, the config for the sub-interface is
interface ATM3/0.36 point-to-point
description PVC ->inverness-gw
bandwidth 39000
ip address 10.254.10.2 255.255.255.252
ip ospf cost 100
atm pvc 36 0 36 aal5snap 39000 35000 inarp oam 10
end
paolo bevilacqua
Beside nbar (that often is unable to classify properly) can you clarify what is that you want to shape and how you tried to do so ?
Also recommend you use the newer command "pvc 0/3" and "vbr" under it to configure an ATM PVC. You don't need inarp for a p-t-p link.
I created the class-maps and policy-maps given below, I them applied them to the interface with the command "service-policy output QoS-Policy-2" . I am trying to create a general prioritisation scheme on the network as we have a mixed bag of traffic types, fairly high utilisation and our VC and telephone traffic is suffering.
class-map match-any Transactional-1
match protocol finger
match protocol notes
match protocol novadigm
match protocol pcanywhere
match protocol secure-telnet
match protocol sqlnet
match protocol sqlserver
match protocol ssh
match protocol telnet
match protocol xwindows
match protocol citrix
class-map match-any Signaling-1
match protocol h323
match protocol rtcp
match protocol sip
class-map match-any Routing-1
match protocol bgp
match protocol egp
match protocol eigrp
match protocol ospf
match protocol rip
match protocol rsvp
class-map match-any Voice&Video-1
match protocol rtp audio
match protocol h323
match protocol rtp video
class-map match-any Management-1
match protocol dhcp
match protocol dns
match protocol imap
match protocol kerberos
match protocol ldap
match protocol secure-imap
match protocol secure-ldap
match protocol snmp
match protocol socks
match protocol syslog
class-map match-any voice
match protocol rtp
policy-map QoS-Policy-1
class Voice&Video-1
set dscp ef
priority percent 33
class Signaling-1
set dscp cs3
bandwidth percent 5
class Routing-1
set dscp cs6
bandwidth percent 5
class Management-1
set dscp cs2
bandwidth percent 5
class Transactional-1
set dscp af21
bandwidth percent 5
class class-default
fair-queue
random-detect
policy-map QoS-Policy2
class class-default
shape average percent 100
service-policy QoS-Policy-1
Hi, beside that your policy map appears to be an overkill, you should configure the pvc as suggested above. After that you will be able to attach a policy map to it.
I'll confirm both Paolo's posts. Have used service policies within ATM PVC as he describes.
What may not be clear, with what Paolo is suggesting, you also get an implicit shaper, although I believe its FIFO, but that's where the policy comes in.
I also agree with Paolo your policy might me a bit of "overkill", looks like something Enterprise AutoQoS would generate.
If some real-time traffic is the issue, drop it into a LLQ and everything else WFQ.
E.g. (pseudo config)
class-match match-all real-time
match (your real-time traffic - could be nbar protocol, could be dscp, could be acl)
policy-map cbwfq
class real-time
priority percent 30
class class-default
fair-queue
atm #/# point-to-point
ip address ...
pvc #/#
vbr-nrt (pvc's pcr/scr/burst)
service-policy output cbwfq
PS:
BTW: you don't need NBAR protocol-discovery to use NBAR to match; protocol-discovery is used to gather NBAR analysis traffic stats
