Qos : bandwidth limitation on Ethernet port
jfbesnardeau
I have a router connected via an Ethernet port to 100 duplex Mbps/Full towards an operator limiting the band-width to 4Mbps. How can I make so that my policy-map associated with the Voip treatment is put in function as of the use of the 4Mbps?
PAUL TRIVINO
Level 3
Level 3
You should be able to use a policing or shaping policy to limit the BW on an Ethernet port. Policing if the 4Mbps limit is absolute, shaping if some bursting is allowed.
Paul
mounir.mohamed
Level 7
Level 7
Dear Sir,
We can use Policing, or apply rate-limit that matching on DSCP-EF or even ACL
CAR Matches on DSCP EF (Voice)
rate-limit input dscp 46 4000000 750000 1500000 conform-action transmit exceed-
action drop
CAR matches on ACL 101 which matches on the RTP payload port range.
rate-limit input access-group 101 4000000 750000 1500000 conform-action transmi
t exceed-action drop
The above values for 4M traffic.
Best Regards,
Mounir Mohamed
v_milenko
You can you this sample config to limit bandwidth about 4 Mbps and have priority queueing for voip traffic with bandwidth 50% from 4 Mbps.
Example config
class-map match-all voice
match ip dscp ef
policy-map qos-policy
class voice
priority percent 50
class class-default
fair-queue
random-detect
policy-map fasteth-4mb
class class-default
shape average 4000000
service-policy qos-policy
interface FastEthernet0
service-policy output fasteth-4mb
Of course you can use this policy only in output direction.
Victor
