QoS (CBWFQ) on Cisco 1812
terencesteve
Hello
i'm working with a Cisco 1812 Router for my Diploma Thesis.
One of the targets is to realize a QoS Situation.
The main idea behind is to stress 2 Ports with incoming traffic
and to sort the traffic on 1 outgoing port.
I've marked the packets with Diffserv under IxChariot. To match
them i've created 4 Access-lists. 2 for each Incoming Port. 2 Lists,
because i'm working with IPv6 and IPv4. I've put each Access-list into
one Traffic Class. Attached all this traffic-classes with one
policy to the outgoing Interface. The 2 Input Interfaces are WAN
Interfaces. The outgoing Interface is a VLAN Interface attached
to one of the switchports of the internal 8-port switch.
After testing the configuration, i've realized, that the access-lists,
have matched the packets correctly, but the service-policy wasn't
able to handle the bandwidth regarding to the definitions within
the traffic classes. At least i tried to give one IPv6 Traffic ab better
bandwidth than the other. Before i've tried the same with only IPv4, with
the same result - wasn't able to handle the service-policy.
Could you please be so kind and take a closer look at my configuration?
Best regards,
Terence Steve
version 12.4
hostname RouterB
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
ipv6 unicast-routing
class-map match-all classv62
match access-group name background
class-map match-all classv61
match access-group name excellent
class-map match-all class2
match access-group 102
class-map match-all class1
match access-group 101
policy-map policy1
class class1
class class2
class classv61
bandwidth percent 70
class classv62
bandwidth percent 5
class class-default
interface BRI0
no ip address
shutdown
interface FastEthernet0
ip access-group 101 in
duplex auto
speed auto
ipv6 address 2001:DB8:1::/48 eui-64
ipv6 traffic-filter excellent in
ipv6 rip process1 enable
no shutdown
interface FastEthernet1
ip address 192.168.2.1 255.255.255.0
ip access-group 102 in
duplex auto
speed auto
ipv6 address 2001:DB8:2::/48 eui-64
ipv6 traffic-filter background in
no shutdown
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Vlan2
ip address 192.168.3.1 255.255.255.0
ipv6 address 2001:DB8:3::/48 eui-64
service-policy output policy1
router rip
version 2
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
ip classless
no ip http server
no ip http secure-server
access-list 101 permit ip host 192.168.1.2 host 192.168.3.2 dscp cs5
access-list 102 permit ip host 192.168.2.2 host 192.168.3.2 dscp cs1
ipv6 router rip process1
ipv6 access-list excellent
permit ipv6 host 2001:DB8:1:0:215:2BFF:FEBE:DE84 host 2001:DB8:3:0:215:2BFF:FEBE:DE83 dscp cs5
ipv6 access-list background
permit ipv6 host 2001:DB8:2:0:215:2BFF:FEBE:DE85 host 2001:DB8:3:0:215:2BFF:FEBE:DE83 dscp cs1
control-plane
line con 0
line aux 0
line vty 0 4
login
no scheduler allocate
end
paolo bevilacqua
Hi, a LAn interface is never congested hence QoS never kicks in. And even i it was congested, a 1812 route can't keep up with wire-speed fastethernet trafic.
Either you configure a parent/child type of policy-map to shape first, or you do your testing on a low speed interface. Typically, back-to-back serial interfaces are used for the purpose.
Are you sure, that a 1812 can't handle it? Because i've meassured an output around 80MBit/s (goodput). IxChariot shows the result as 2x40MBits/s (2 Streams).
But i will follow your advise and i'm going to
check it with a chield policy in combination with shaping.
Shaping has no effect. Has anyone else an idea?
I've found a solution by myself. Just changed the outgoing VLAN with one ingoing WAN interface. Now it works.
