QOS - CISCO Bug ?
guruprasadr
Level 7
Level 7
Hello Experts,
My,
CISCO Router: 3700 Series
Version: Version 12.3(20)
Sample Class-Map Configuration:
Class Map match-any Customer_Room
Match access-group 122
Detail: In the above Class Map Configuration i was NOT able to Match the "NAMED ACL" access-group.
Only the ACL with "ACL Index Number" can only be Matched.
Was this some CISCO IOS Bug ? (or) Have someone experienced this Problem before ?
But in the CISCO QOS config document, i am seeing the options to Match the "Named ACL".
Pls add your Comments. Thanks in Advance.
Best Regards,
Guru Prasad R
royalblues
Level 10
Level 10
Guru,
It definitely supports named access-lists and was able to use them without any problems. It could be a possibilty that you might have got the sytax wrong
This is what i tried
ip access-list extended exchange
permit ip host 172.16.150.5 any
permit ip host 172.20.61.60 any
class-map match-any exchange
match access-group name exchange
Narayan
HI Narayan,
Thanks for INFO. I am adding more details on my Configuration:
ip access-list extended QOS_Customer_Room
permit ip any host
permit ip host any
class-map match-any Customer_Room
match access-group name QOS_Customer_Room
My "Named ACL = QOS_Customer_Room" ==> when matching above Named ACL in Class-map, it doesn't Support.
Question:
Whether the Special Character's like "_" used in the Named ACL will not be recognised / supported by QOS Configuration ? ?
Please let me know your Comments / Feedback.
Best Regards,
Guru Prasad R
Guru,
That should not be a problem. Anyway can you let me know the exact IOS you are using.
Narayan
HI Narayan,
IOS : flash:c3745-is-mz.123-20.bin
Pls check and let me know. Thanks in Advance.
Best Regards,
Guru Prasad R
