QOS Config issue
Dhiraj Jagdale
Hii,
We have one branch with bandwidth of 512 Kbps, we want to reserve bandwidth 256 Kbps for a IP address range 10.32.131.0/24. to achieve this we apply below QOS config in router,
class-map match-all CITRIX
 match access-group 101
policy-map Citrix-policy
 class CITRIX
    bandwidth 256
access-list 101 permit ip any 10.32.131.0 0.0.0.255
access-list 101 permit ip 10.32.131.0 0.0.0.255 any
We have apply this policy to router WAN link connected interface as showing below,
Router(config)#interface FastEthernet0/0/0
Router(config-if)#
Router(config-if)#service-policy output Citrix-policy
Router(config-if)#
Router(config-if)#service-policy input Citrix-policy
Weighted Fair Queueing feature not supported in input policy.
But when we tried to apply this policy inward then above mention error is showing.  Is this my configuration write ? if yes then how can i overcome this issue ? if no plese share me correct config
Thanxs in advance.....
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The bandwidth statement is only an egress QoS feature.
You can police traffic, both ingress and egress, but the police statement's behavior is different from a bandwidth statement.  I.e. it might not be suitable.
Ideally, you apply an egress policy on the other side's egress to effect ingress traffic.
Joseph W. Doherty
Disclaimer
Posting
Hii Joseph, Thanks for the reply
But i have one doubt, is that my configuration correct ? because i want to reserve the bandwidth of 256 Kbps for traffic between IP address range 10.32.131.0/24 and branch LAN ip range.
i have applied policy on other site an egress traffic and when i am putting load on link by using source and destination ip addresses by same as in access list or different than access list then link is utilizing up to 512 Kbps.
if i specify the 256 Kbps of bandwidth than link should be utilize to specified limit only or it will be utilize to peak level ?
Disclaimer
Posting
Peak level.  The bandwidth statemetn provides a minimum bandwidth guarantee.  More may be used.
