01-10-2011 11:55 PM - edited 03-04-2019 11:02 AM
Hi all!
I need to match DSCP valures of EF and AF41 and make QoS queues for them, I've made the following configuration, I just wanted you guys to check it..
### QoS SDM - CISCO ####
Class-map voice
match ip dscp EF
exit
class-map video
match ip dscp AF41
exit
policy-map policy1
class voice
priority percent 10
class video
priority percent 10
class class-default
fair-queue
##### config-if ####
service-policy output policy1
Will that work??
Best Regards, Steffen.
Solved! Go to Solution.
01-17-2011 04:25 AM
Yes, if there will be congestion, this will work. But no sure about if you want it :).
When congestion take place ( hardware queue of physical interface is full), so on Fastethernet when there is more then 100Mbps going to that link.
When congested, Qos will look like this:
Max 25% of aviable bandwidth will be size of priority queue, that will be shared by Voice, Video and ShareApp.
Voice and video will have 10mbps on that link, and ShareAPP will have %mbps.
Min 50% of a link will be aviable for all other traffic.
Input is for marking and policing. Output is for Shaping, policing, marking ...
01-11-2011 01:22 AM
Hi Steffen
I would go with bandwidth command under class class-default as well. I hope you are reserving only 75% of the available bandwidth in that case you may have to put bandwidth 55% since you have allocated 20% to other classess.
If you want to have more granular QoS class definition you may have to choose 11 point class model based on your requirement so that you do justice for all the traffic pattern available in your network.
regds
01-12-2011 06:00 AM
I've now made an markingpolicy and a LLQ queue policy. Here Is the Output from the LLQ policy:
Service-policy output: LLQ
Class-map: VoIP (match-any)
510 packets, 280593 bytes
5 minute offered rate 8000 bps, drop rate 0 bps
Match: access-group 101
396 packets, 274323 bytes
5 minute rate 8000 bps
Match: dscp ef (46)
114 packets, 6270 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 10 (%)
Bandwidth 10000 (kbps) Burst 250000 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: class-default (match-any)
154920 packets, 42145404 bytes
5 minute offered rate 786000 bps, drop rate 0 bps
Match: any
Queueing
Output Queue: Conversation 265
Bandwidth 50 (%)
Bandwidth 50000 (kbps)Max Threshold 64 (packets)
(pkts matched/bytes matched) 457/77091
(depth/total drops/no-buffer drops) 0/0/0
I do not understand why packets are matched in the VoIP class
( Match: access-group 101
Match: dscp ef (46)
5 minute rate 0 bps
But no packets are going into thequeue:
How can there be a match whitout any packets going to the LLQ queue??
Regards, Steffen.
01-12-2011 08:02 AM
Can you post your configuration here?
regds
01-12-2011 11:39 PM
Extended IP access list 101
10 permit udp any any range 50000 50050 (49650 matches)
Extended IP access list 102
10 permit udp any any range 51000 51050 (23 matches)
Extended IP access list 103
10 permit tcp any any range 52000 52010 (529 matches)
KOL-1812#sh class-map
Class Map match-any AppShare (id 3)
Match access-group 103
Match dscp af31 (26)
Class Map match-any VoIP (id 1)
Match access-group 101
Match dscp ef (46)
Class Map match-any class-default (id 0)
Match any
Class Map match-any Video (id 2)
Match access-group 102
Match dscp af41 (34)
KOL-1812#sh policy-map
Policy Map LLQ
Class VoIP
Strict Priority
Bandwidth 10 (%)
Class Video
Strict Priority
Bandwidth 10 (%)
Class AppShare
Strict Priority
Bandwidth 5 (%)
Class class-default
Bandwidth 50 (%) Max Threshold 64 (packets)
Policy Map markingpolicy
Class VoIP
set dscp ef
Class Video
set dscp af41
Class AppShare
set dscp af31
Class class-default
interface FastEthernet0
description Kolding WAN
service-policy output LLQ
interface FastEthernet1
description Kolding LAN
service-policy input markingpolicy
KOL-1812#sh policy-map interface fastEthernet 1
FastEthernet1
Service-policy input: markingpolicy
47567 packets, 9126266 bytes
5 minute offered rate 1000 bps, drop rate 0 bps
47504 packets, 9122486 bytes
5 minute rate 1000 bps
Match: dscp ef (46)
63 packets, 3780 bytes
5 minute rate 0 bps
QoS Set
dscp ef
Packets marked 47567
Class-map: Video (match-any)
23 packets, 4324 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 102
0 packets, 0 bytes
5 minute rate 0 bps
Match: dscp af41 (34)
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set
dscp af41
Packets marked 23
Class-map: AppShare (match-any)
529 packets, 40343 bytes
Match: access-group 103
0 packets, 0 bytes
5 minute rate 0 bps
Match: dscp af31 (26)
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set
dscp af31
Packets marked 529
10536310 packets, 7100592447 bytes
5 minute offered rate 1388000 bps, drop rate 0 bps
Match: any
KOL-1812#sh policy-map interface fastEthernet 0
FastEthernet0
3669 packets, 787226 bytes
3604 packets, 783651 bytes
5 minute rate 0 bps
Match: dscp ef (46)
65 packets, 3575 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Bandwidth 10 (%)
(pkts matched/bytes matched) 1/152
0 packets, 0 bytes
0 packets, 0 bytes
5 minute rate 0 bps
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Bandwidth 10 (%)
0 packets, 0 bytes
0 packets, 0 bytes
5 minute rate 0 bps
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Bandwidth 5 (%)
Bandwidth 5000 (kbps) Burst 125000 (Bytes)
148723 packets, 69633897 bytes
5 minute offered rate 1121000 bps, drop rate 0 bps
Match: any
Queueing
Bandwidth 50 (%)
(pkts matched/bytes matched) 968/127527
KOL-1812#
As said before the packets are matched in the LLQ policy, but no packets are going into the queue.
But yesterday I tried to generate more traffic, and it seems when the traffic load was high the packets where matched AND where putted into the queue. Can It be right that the packets only are putted into the queue, when there is a lot of traffic on the link?
Regards, Steffen.
01-17-2011 03:22 AM
Will you please confirm that the above configuration will work?
Best Regards,
Steffen.
01-17-2011 03:42 AM
QoS congestion management techniques like LLQ, CBWFQ( priority or bandwidth commands) always come into play only when there is congestion.
So if there is no congestion then nothing in the software queues, that is normal behavior.
Regards.
Alain.
01-17-2011 03:55 AM
Thanks for your reply.
And if my linies be congested, will the above configuration then still work?
I'm not sure about when to use output or input when applying a policy-map to an Interface.
01-17-2011 04:25 AM
01-17-2011 04:32 AM
and if i set the bandwidth command on the interface to for example 10mbps, it will be congested when reaching this bandwidth?
01-17-2011 04:41 AM
No. bandwidth parametr of an inferface is only "information", doesn't limit traffic.
POLICING is what you are looking for.
Here is an explanation with an example:
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800a3a25.shtml
01-17-2011 05:00 AM
Hmm, But i don't want to limit the bandwidth to my users, I only want to prioritizing my VoIP, Video, and AppShare data.
So if someone is loading a file from our file server from a remote office, his bandwidth will be limited if someone i making a VoIP call. But if there is no VoIP call he should have full bandwidth.
then its shaping right?
01-17-2011 05:21 AM
No Shaping is like policing but instead of dropping packets it buffers them to transmit later this used as oversubscription prevention not to limit
user traffic.
if you use LLQ then the traffic with priority command will always get the bandwidth you set and not more, the traffic with the bandwidth command will get the minimum bandwith you set but if other class is not using traffic then it can take bandwidth from it.
But then again I repeat all this is in times of congestion and it must be applied output as it is congestion management.
Regards.
Alain.
01-17-2011 05:33 AM
cadetalian has right.
If you have a problem with congestion on fastethernet interface (time to time more then 100mbps need to be send), then shaping is what you need.
If 100mbps fastethernet interface is not congested and you recognize problems with VoIP quality, then shaping is not enought.
01-17-2011 05:49 AM
OK. Then LLQ queue must be the right choise to VoIP.
When thinking in Output and Input, is it then from "the routers middle" I should "look" from?
