01-09-2020 06:16 AM
I have two separate streams at the input of my L3 switch. The first stream is marked EF and the second is marked AF11.
I would like to check that the EF traffic is prioritized in case of congestion.
I started by configuring two separates class-map that match DSCP 46 for EF and DSCP 10 for AF11.
I am stuck in the configuration of the policy-map, how can I do that ?
Thank you in advance
Solved! Go to Solution.
01-09-2020 09:04 AM
Can you post your config for the class-maps? Once you configure you class-maps, you can configure your policy-maps like this:
policy-map xxx-OUT
class-map ef-data
priority percent 10
class xxx
bandwidth remaining percent 50
class xxx
bandwidth remaining percent 45
class class-default
There are tons of different variations you can do with QoS depending on what your goals are. My example above is a very basic example.
01-09-2020 09:04 AM
policy-map xxx-OUT
class-map ef-data
priority percent 10
class xxx
class xxx
class class-default
01-09-2020 09:24 AM
