Showing results forĀ
Search instead forĀ
Did you mean:Ā
QoS conversion
12pratham
Hi Experts ,need help from converting the QoS configuration from CatOS  switch Nexus 7k.Please advise me on this to proceed further.
alitadir
Hi 12pratham, as far as I know there is only CatOS to IOS conversion tool. But I think it would be easier to convert IOS configuration to the NXOS than converting CatOS to NXOS.
Ali TADIR
Can I convert the config from CatOS to IOS using the EDI converter, and after that convert the config from IOS to NXOS. is it possible to do this way.
Is there any tool to convert IOS to NXOS.Please let me know.
12pratham, the problem is the conversion from IOS to NXOS. There is no tool to do it.
I think you have to convert it manually. But converting from CatOS to IOS will make your job easy. Because IOS configuration will be easy to understand. That's why I suggest that converting it to IOS.
Ali
I tried installing cisco EDI 2.2 version ,getting an error message when I try to open it.
Please help me in conversting below commands to NXOS
set qos enable
set qos map 2q2t tx 2 1 cos 1
set qos drop-threshold 2q2t tx queue 1 100 100
set qos map 1p1q4t rx 1 3 cos 1
set qos wrr 1p2q2t 50 255
set qos wred 1p2q2t tx queue 1 70:100 70:100
set qos wred 1p2q2t tx queue 2 70:90 100:100
set qos map 1p3q1t tx 2 1 cos 1
set qos map 1p3q1t tx 3 cos 6
set qos wrr 1p3q1t 20 100 200
set qos wred 1p3q1t tx queue 3 70:90
set qos map 1p1q0t rx 2 cos 7
set qos map 1p2q1t tx 2 1 cos 1
set qos map 1p2q1t tx 2 cos 6
set qos wrr 1p2q1t 50 255
set qos txq-ratio 1p2q1t 70 15 15
set qos wred 1p2q1t tx queue 2 70:90
set qos cos-dscp-map 0 10 18 26 34 46 48 56
set qos ipprec-dscp-map 0 10 18 26 34 46 48 56
set qos policed-dscp-map 0,24,46:0
