QOS - division of unused bandwidth
diepes
Can someone explain to me how unused bandwidth (Allocated to a class but not used) is divided when a policy is applied to a interface ?
Is it according to there bandwidth allocation,
diepes
Here is a page stating, that unused bandwidth is allocated according to the size of the class.
Can anyone confirm this ?
How much will be allocated to the default class, if has not been assigned a % of bandwidth ?
http://www.cisco.com/warp/public/105/priorityvsbw.html#howisunusedbandwidthallocated
That is correct. Classes with bandwidth or priority statements configured will get the first chance to use up any spare bandwidth. If there is still some bandwidth remaining, it will go to class-default.
Consider the following:
policy-map Test
class1
band 128
class2
band 256
If the above polocy is applied to a 512k link and the offered traffic is:
512k for class1 and
512k for class2,
the resulting allocation of bandwidth will be:
class1 will get 128/(128+256)*512 = 171k
class2 will get 256/(128+256)*512 = 341k
Class-default will get nothing.
Hope that helps - pls rate the post if it does.
Paresh
