03-14-2006 07:01 AM - edited 03-03-2019 12:03 PM
Am I better to place the CBAC inspection on the outside "out" or inside "in" interface?
Is there a rule as with standard and exteneded ACLs?
Solved! Go to Solution.
03-14-2006 03:23 PM
Yes, I would also think that it's better to apply it in the outside interface because that is more likely to be the point of entry for malicious traffic.
Paresh
03-14-2006 03:11 PM
The general rule with filtering is to filter as early as possible. However, your circumstances will dictate whether you place it on the inside or the outside interface.
Paresh
03-14-2006 03:16 PM
I'm guessing unless I need specific inspections for the inside "in" ie DMZ and LAN I would be better putting this on the outside "out" to prevent un-necessary traffic coming into the router then getting dropped?
I ask because I inherited two routers on a new network, one seems to filter on LAN other onthe outside.
03-14-2006 03:23 PM
Paresh
