QoS DSCP EF with 3750-X
pboegli77
I'm testing QoS with a 3750-X
I want to mark traffic in the 192.168.126.0/24 subnet with DSCP EF.
I've entered this command :
mls qos
class-map match-any class_126
  match access-group 2
policy-map mark_dscp_126
class class_126
   set dscp ef
access-list 2 permit 192.168.126.0 0.0.0.255
And I affect this policy to port 8 :
service-policy input mark_dscp_126
I've a PC on port 8 with IP 192.168.126.1 and I'm doing an iperf test with an other PC :
Without policy :
[ ID] Interval       Transfer     Bandwidth
[  4]  0.0- 3.0 sec   273 MBytes   763 Mbits/sec
[  4]  3.0- 6.0 sec   276 MBytes   772 Mbits/sec
[  4]  6.0- 9.0 sec   275 MBytes   770 Mbits/sec
[  4]  0.0-10.0 sec   916 MBytes   768 Mbits/sec
With policy :
[  4]  0.0- 3.0 sec  15.1 MBytes  42.3 Mbits/sec
[  4]  3.0- 6.0 sec  13.6 MBytes  37.9 Mbits/sec
[  4]  6.0- 9.0 sec  12.5 MBytes  35.1 Mbits/sec
[  4]  0.0-10.3 sec  46.1 MBytes  37.7 Mbits/sec
Why bandwith is limited when traffic is marked ?
Did you enter 'priority-queue out' under all interfaces?
5 Replies 5
pboegli77
When I mark traffic with DSCP AF11, there is no problem...
I'v a high bandwith...
Is there any shaping applied on the interface
Can you post the interface config
No shaping...
interface GigabitEthernet1/0/8
switchport trunk allowed vlan 8,62,120,122-126,128,129,172
switchport mode trunk
Ans also :
gw_c3750_ma_01#sh mls qos input-queue
Queue     :       1       2
buffers   :      90      10
bandwidth :       4       4
priority  :       0      10
threshold1:     100     100
threshold2:     100     100
gw_c3750_ma_01#sh mls qos queue-set
Queueset: 1
Queue     :       1       2       3       4
buffers   :      25      25      25      25
threshold1:     100     200     100     100
threshold2:     100     200     100     100
reserved  :      50      50      50      50
maximum   :     400     400     400     400
Queueset: 2
Queue     :       1       2       3       4
Thank you
Thank you, with "priority-queue out", the bandwith is high again
