QoS for 100mb circuit on 1000mb interface
Jeff Ferrell
Hello, we recently turned up a 100mb circuit between sites, and it is leaving a 1gb interface.
WIth my current QoS setup, I have set the serial bandwith to ~45mb and set my policy map to total less than that. I have the max-reserved-bandwidth set to 90.
With my new interface, what is the easiest way to stop the router from sending 1gb of traffic? I know I can setup shaping and exceed action for each class, but could I just put max-reserved-bandwidth 10 to "shape" the entire interface down to 100mb then leave my class setup as it is? I'd rather see the drops tehn let the carrier do the dropping.
policy-map DR-WANEdge
class DR-Voice
  set dscp ef
  priority 6144
class DR-Signal
  set dscp cs3
  bandwidth 1600
  random-detect
class Business_Data
  set dscp af31
  bandwidth 30720
  random-detect dscp-based
class Network_Control
  set dscp cs6
  bandwidth 1536
  random-detect
class DR-SAN
  set dscp af11
  bandwidth 15346
class DR-Cameras
  set dscp cs4
  bandwidth 8192
  random-detect
class Scavenger
  set dscp cs1
  bandwidth 1024
class class-default
  set dscp default
  bandwidth 8192
  random-detect
2 Accepted Solutions
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
policy-map DR-WANEdge-100Mbps
class class-defautl
shape average 100000000
service-policy DR-WANEdge
Add above policy.  Use on egress interface (out).
Disclaimer
Posting
What I don't understand now is in the shape policy, everything is considered the "default class". Is that b/c we are simply trying to shape ALL traffic and make congestion at the 100mb mark?
Yes, correct.
Then when you call my actual queue and classification policy via the "service-policy DR-WANEdge" command, it then applies the real class maps and priorities?
Yes, it then is used to prioritize the 100 Mbps.
Basically, the parent shaper makes the gig interface act like a FE interface, which we then have a policy against.
7 Replies 7
Joseph W. Doherty
Disclaimer
Posting
class class-defautl
Thanks. I already have the policy I posted (needing to tweak the bandwidth numbers still) on the egress interface out.
Should I take the shape average command and divide it up on each class map as well as leave the bandwidth?
Disclaimer
Posting
Yes, I understand.  That's why I wrote add the policy I provided.  It uses your existing policy to managed the shaped traffic.
Normally, no.
Ah I see now JosephDoherty,
I didnt' quite understand it at first. What I don't understand now is in the shape policy, everything is considered the "default class". Is that b/c we are simply trying to shape ALL traffic and make congestion at the 100mb mark?
Disclaimer
Posting
Yes, correct.
Do you know whats your peak traffic rate is at present?
Your new qos b/w allocation totaling 73mb , this is still under the default reserved 75% bw for the 100mb interface,
So even without speicifying the reserved-bandwidth to 90%, and this would leave 25mb for the class class default  to be shared between all other classes in proportion to their b/w  allocation numbers if it isn't being utilized.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
pdriver,
Right now we max the 45mb often due to SAN and backup replication, not sure how high it will really go. I will leave much less (5mb maybe for the class default, as what I need to ensure gets through is in the business_data class, default I don't care much about.
