Showing results forĀ
Search instead forĀ
Did you mean:Ā
QoS for IPSEC(port 500,4500)
z.elguesmi
hello,
please  you have any idea how can I configure QoS in the router CISCO1841 for  the port IPSEC(UDP 500 ,UDP 4500) and the port tcp 4433
thx for your help
5 Replies 5
Simon Brooks
Create an acl matching the port numbers. Create class map matching the acl. The create your policy map defining what you want do with it I.e. police/prioritise etc then apply to interface. That what you're after?
Sent from Cisco Technical Support Android App
I did that :
class-map match-all test
match protocol ipsec
policy-map qostest
class test
  bandwidth 1536
interface FastEthernet0/1
ip address X.X.X.X 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
service-policy output qostest
its looks good ?
and how I can test if that work or no
thx
Simon Brooks
Show policy-map int fa0/1
Look for hits in the class.
Matching a protocol? Have you got nbar turned on?
I did show policy-map int fa0/1 and I had this :
############ when i did not use the VPN ###########################
1841#show policy-map interface fastEthernet0/1
FastEthernet0/1
  Service-policy output: qostest
    Class-map: test (match-all)
      11083 packets, 1580794 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: protocol ipsec
      Queueing
        Output Queue: Conversation 265
        Bandwidth 1536 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 2/236
        (depth/total drops/no-buffer drops) 0/0/0
    Class-map: class-default (match-any)
      10542255 packets, 1927566731 bytes
      5 minute offered rate 12000 bps, drop rate 0 bps
      Match: any
###############  when i use the vpn ##############################
FastEthernet0/1
      11096 packets, 1583464 bytes
      5 minute offered rate 2000 bps, drop rate 0 bps
      Queueing
      10542690 packets, 1927611628 bytes
      5 minute offered rate 6000 bps, drop rate 0 bps
      Match: any
for your question : " Matching a protocol? Have you got nbar turned on? "
I did not understand
Simon Brooks
So it is working then? I think matching a protocol turns on nbar anyway so don't worry about that.
