NAT device
we have A wireless link (pre-wimax) that provide me with 2 Mb internet connection (tagged Ethernet frames) and we have 6 real IP what i need now is what is the best and cheapest device to do NAT and DHCP to allow users to access the internet , i am trying to do this using Cisco AP 1141 and the link is working fine with static ip configuration on my lap (give my wireless NIC real IP) but now i just need device to do NAT and DHCP
my suggestion is can i use  Cisco 861W to do this function
any help will be appreciated
Edison Ortiz
Yes, you can use the 861W router.
Thanks Edison for your help
and kindly advice on those questions below and the below scenario
1-is the WAN port on this router support tagged ethernet frames ??? or even untagged frames
2-is the 4 ports on the router can be used as WAN or LAN ???
3- can i give this router WAN interface one of those public IPs and give the rest of those IPs statically to other devices on the network
WAN Interface to the pre-wimax device-----------2nd 10/100 port----------Router----------1st 10/100 port ------LAN interface users (DHCP )
NAT on router to translate from private IPs on LAN interface  to public IPs on WAN interface
thanks in advance
1) The typical configuration for the WAN port is a routed port but I believe you can also configure subinterfaces which alllows for the tag frame support.
2) LAN
3) Yes
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/SCG880-860.html
Hi Edison,
     Thanks for your help and support , could you please confirm the availability of the WAN port to deal with tagged ethernet frames
Thanks in advance
