QOS for Polycom Video Conference
richreitenauer
Setup:
Site A Cisco 2911 -- 2 T1 WIC.  One going to Site B 1841 another going to Site C 1841.
I am looking for a way to setup a Polycom QOS, judging by several forum posts about this, would it be better to create an access list with the Polycom IPs to limit the bandwidth to 512Kbps?  Or if not, could someone send a link for Polycom QOS configs?  What is happening is when noone else is using the connection except for the video conference, after about an hour with the T1 not being 100 % utilized, the 2911 GE0/0 interface will start developing input queue errors.  What I usually have to do is reboot the router at night and that alleviates the problem since regular data traffic will not cause this problem.
2911 running config:
Current configuration : 3529 bytes
version 15.0
service timestamps log datetime msec localtime show-timezone year
service password-encryption
hostname
boot-start-marker
boot-end-marker
card type t1 0 0
card type t1 0 1
card type t1 0 2
no aaa new-model
clock timezone gmt -5
clock summer-time cdt recurring
no network-clock-participate wic 0
no network-clock-participate wic 1
no network-clock-participate wic 2
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO2911/K9 sn FTX1513ALLS
controller T1 0/0/0
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/0/1
clock source internal
controller T1 0/1/0
channel-group 3 timeslots 1-24
controller T1 0/1/1
channel-group 2 timeslots 1-24
controller T1 0/2/0
controller T1 0/2/1
buffers middle permanent 200
buffers middle max-free 230
buffers middle min-free 50
buffers big permanent 75
buffers big max-free 200
buffers big min-free 15
buffers verybig permanent 20
buffers verybig max-free 20
buffers tune automatic
interface Multilink1
ip address 192.168.200.1 255.255.255.252
ip flow ingress
ip flow egress
load-interval 30
ppp multilink
ppp multilink group 1
ppp multilink fragment disable
no cdp enable
hold-queue 4000 out
interface GigabitEthernet0/0
ip address 10.10.3.1 255.255.240.0
ip flow ingress
ip flow egress
duplex full
speed auto
no cdp enable
hold-queue 240000 in --- Just changed it...used to be 3000
hold-queue 240000 out  --- Same thing but used to be 4096
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
no ip address
encapsulation ppp
ppp multilink
no fair-queue
hold-queue 40 out
interface Serial0/0/1:0
no ip address
encapsulation ppp
ppp multilink
no fair-queue
hold-queue 40 out
interface Serial0/1/0:3
ip address 192.168.1.2 255.255.255.0
ip flow ingress
ip flow egress
load-interval 60
no fair-queue
hold-queue 200 in
hold-queue 4000 out
interface Serial0/1/1:2
ip address 192.168.8.2 255.255.255.0
ip flow ingress
ip flow egress
load-interval 30
no fair-queue
hold-queue 200 in
hold-queue 4096 out
interface Serial0/2/0:0
no ip address
encapsulation ppp
ppp multilink
no fair-queue
interface Serial0/2/1:0
no ip address
encapsulation ppp
ppp multilink
no fair-queue
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-cache timeout active 1
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination
ip route 0.0.0.0 0.0.0.0 10.10.18.1
ip route 10.10.1.0 255.255.255.0 192.168.1.1
ip route 10.10.5.0 255.255.255.0 192.168.8.1
ip route 10.10.9.0 255.255.254.0 192.168.200.2
logging trap notifications
logging
snmp-server community
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
session-timeout 60
privilege level 15
logging synchronous
login
transport input telnet
scheduler allocate 20000 1000
end
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
For a live video stream, you might define a QoS service policy to place it into LLQ.  Or, you might provision the policy to give in enough priority where it's almost treated like LLQ.
Unclear why you would want to limit the Polycom traffic to 512 Kbps.  Live video streams often don't well tolerate excessive delay or much packet loss.
You could identify the Polycom traffic in several way.  I vaguely recall Polycoms might support tagging their packets with different markings; might only be a choice of IP Prec, but that's usable too.
As to your input queue error, that's difficult to say without much more in detail.  Might be a bug.
