QoS for voice on a multi-link frame relay interface / subinterface
Michael Marzol
My question is in regards to QoS on an MFR interface/subinterfaces. We have a remote site with two bundled T1's terminating on a 2951 router for a total bandwidth of 3072. The circuit is provided by Paetec and the subinterfaces are designated for internet and MPLS traffic respectively. The issue we are facing is with outbound voice quality. It seems that no matter how we apply QoS, either to the main MFR interface or the MFR subinterfaces, voice packets do not seem to be prioritized. We tried FRTS, which slowed the entire link down to a crawl, we tried applying a class map to the main interface as well as a service policy, none of which seemed to affect anything. Please see below for current partial configuration. Any input will be greatly appreciated.
class-map match-all VOICE
match ip dscp ef
class-map match-any SIGNALING
match ip dscp af31
match ip dscp cs3
class-map match-all AZ-SERVERS
match access-group 10
policy-map VOICE-POLICY
class VOICE
    priority 640
class SIGNALING
    bandwidth 64
  set dscp af41
class AZ-SERVERS
    police 1000000
class class-default
    fair-queue
interface Loopback1
no ip address
interface Tunnel1
no ip address
interface MFR1
no ip address
ip flow ingress
ip flow egress
load-interval 30
frame-relay lmi-type ansi
service-policy output VOICE-POLICY
interface MFR1.501 point-to-point
description => Internet via PAETEC
ip vrf forwarding internet
ip address 63.255.X.X 255.255.255.252
ip flow ingress
ip flow egress
no cdp enable
frame-relay interface-dlci 501 IETF
interface MFR1.502 point-to-point
description => MPLS VPN via PAETEC
ip address 63.253.X.X 255.255.255.252
ip flow ingress
ip flow egress
no cdp enable
frame-relay interface-dlci 502 IETF
gfcisco31
MAte...
some tips:
-You should configure the policy-map in the Point to point links.
-MAke sure the packets are coming already marked, as your just matching it. (ip flow for checking)
- To conform with the acquired bandwidth, i would make a nested policy map shaping everything.. like:
policy-map SHAPE
class class-default
shape average 3072 (bc standard) (be 0)
service-policy VOICE-POLICY
You can also create another policy map to police the VOICE class (action drop)
policy-map policeVoip
police 640000 conform-action transmit exceed-action drop
class VOICE
    priority 640
    servicy-policy policeVoip
And lastly, remember that voip packets that exceed the priority configured limit will NOT have strict priority (it may get dropped as just another junk traffic)
I hope this helps
Please, rate useful posts.
For this to work as desired, you need to assign the policy only to interface MFR1.502.
It is pretty useless to run qos on an Internet connection because the priority will not be granted in the rest of the path.
Please provide the output of sh policy-map after making the above change.
I am especially curious about the bandwidth values listed in the output.
regards,
Leo
I definitely agree, we've tried that as well. Unfortunatley, you can't apply a policy map containing elements of CBWFQ to sub interfaces.
OK, sounds logical.
Have you tried to remove the fair-queue from the default policy then?
Try to replace it with a bandwidth statement.
regards,
Leo
