QoS help!!!!
Limitless1801
I need some help with a QoS configuration I am trying to apply. I have two router R1 and R1 which are connected via Metro Ethernet. I have configured and applied the QoS configuration show below but as you can see R2 is not matching any of the traffic. The two configurations are identical. What am I doing wrong?
Thanks, RG
Router1
sh ip access-lists
Extended IP access list InternalApps-ACL
    130 permit ip host 172.16.1.46 any (236393444 matches)
    140 permit ip host 172.16.20.51 any (6363243 matches)
    150 permit ip host 172.16.20.52 any (6358344 matches)
    160 permit ip host 172.16.20.53 any (6748823 matches)
    170 permit ip host 172.16.20.54 any (5920358 matches)
    180 permit ip host 172.16.20.55 any (6648240 matches)
    190 permit ip host 172.16.20.56 any (8083640 matches)
    200 permit ip host 172.16.20.57 any (4520785 matches)
    210 permit ip host 172.16.20.58 any (14518513 matches)
    220 permit ip host 172.16.20.59 any (8527696 matches)
    230 permit ip host 172.16.1.123 any (322333615 matches)
    240 permit ip host 172.16.1.124 any (2243133 matches)
class-map match-any VCONTROL
match ip dscp cs3  af31
class-map match-any InternalApps
match access-group name InternalApps-ACL
class-map match-any VOICE-VIDEO
match ip dscp af41  ef
policy-map VGENERIC
class VOICE-VIDEO
  priority percent 40
class VCONTROL
  bandwidth percent 5
class InternalApps
  bandwidth percent 30
class class-default
  fair-queue
interface GigabitEthernet0/1
bandwidth 10000
no ip address
service-policy output VGENERIC
duplex auto
speed auto
interface GigabitEthernet0/1.1896
bandwidth 10000
encapsulation dot1Q 1896
ip address 10.10.10.1 255.255.255.0
Router2
b28-metroe-2851#sh ip access-list InternalApps-ACL
policy-map VGENERIC
class VOICE-VIDEO
  priority percent 40
class VCONTROL
  bandwidth percent 5
class InternalApps
class class-default
  fair-queue
bandwidth 10000
no ip address
ip route-cache flow
duplex auto
speed auto
description MetroE
bandwidth 10000
ip address 10.10.10.3 255.255.255.0
6 Replies 6
pompeychimes
Level 4
Level 4
Shouldn't your ACL on R2 be reversed. I believe you are listing your destination IP's as your source.
James
Sorry. They are. I grabbed the wrong list:
10 permit ip any host 172.16.1.46
    20 permit ip any host 172.16.20.51
    30 permit ip any host 172.16.20.52
    40 permit ip any host 172.16.20.53
    50 permit ip any host 172.16.20.54
    60 permit ip any host 172.16.20.55
    70 permit ip any host 172.16.20.56
    80 permit ip any host 172.16.20.57
    90 permit ip any host 172.16.20.58
    100 permit ip any host 172.16.20.59
    110 permit ip any host 172.16.1.123
    120 permit ip any host 172.16.1.124
Thanks, RG
Shouldn't the policy map be on your LAN interface?
Julio Tenorio
Looks like you need a hierarquical Qos policy.
Please check http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a0080114326.shtml
Cheers
Cheers, Julio Sá
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Believe you'll want the policy applied on your subinterface.  For how, see Julio's reference.
Below are the outputs for the show policy-map interface g0/1. What's confusing me is that it seems to be working on R1 but not in R2 and it's been applied in the same place. When I try to apply on the sub interface, I get the following message:
CBWFQ : Not supported on subinterfaces
I'll take a look at Julio's link and I'll post the results back.
Thanks, RG
Router1
sh policy-map int g0/1 GigabitEthernet0/1
  Service-policy output: VGENERIC
    Class-map: VOICE-VIDEO (match-any)
      9077 packets, 8793813 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: ip dscp af41  ef
        5 minute rate 0 bps
      Queueing
        Strict Priority
        Output Queue: Conversation 264
        Bandwidth 40 (%)
        Bandwidth 4000 (kbps) Burst 100000 (Bytes)
        (pkts matched/bytes matched) 110/92913
        (total drops/bytes drops) 0/0
    Class-map: VCONTROL (match-any)
      13636 packets, 6008897 bytes
      Match: ip dscp cs3  af31
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 265
        Bandwidth 5 (%)
        Bandwidth 500 (kbps) Max Threshold 64 (packets)
        (pkts matched/bytes matched) 299/47840
        (depth/total drops/no-buffer drops) 0/0/0
    Class-map: InternalApps (match-any)
      92269127 packets, 94901895532 bytes
      5 minute offered rate 173000 bps, drop rate 0 bps
      Match: access-group name InternalApps-ACL
        92269123 packets, 94901890335 bytes
        5 minute rate 173000 bps
      Queueing
        Output Queue: Conversation 266
        Bandwidth 30 (%)
        Bandwidth 3000 (kbps) Max Threshold 64 (packets)
        (pkts matched/bytes matched) 3302419/4111735471
    Class-map: class-default (match-any)
      532143302 packets, 401265872472 bytes
      5 minute offered rate 35000 bps, drop rate 0 bps
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 256
        (total queued/total drops/no-buffer drops) 0/0/0
Router2
GigabitEthernet0/1
      0 packets, 0 bytes
      Match: ip dscp af41 (34) ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Strict Priority
        Bandwidth 40 (%)
        (pkts matched/bytes matched) 0/0
      0 packets, 0 bytes
      Match: ip dscp cs3 (24) af31 (26)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Bandwidth 5 (%)
        Bandwidth 500 (kbps)Max Threshold 64 (packets)
      0 packets, 0 bytes
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Bandwidth 30 (%)
        Bandwidth 3000 (kbps)Max Threshold 64 (packets)
      0 packets, 0 bytes
      Match: any
      Queueing
