QOS in Cisco 7600 router // Marking IP precedence
smartboy2255
Dear all,
I have configured below QOS in the router and applied in the outside interface of the router.But no traffic is passing through the default class..Also what will be the impact if the traffic exceeds 30 %.
class-map match-any IPSEC
  match access-group name IPSEC-DATA
class-map match-all FTP
  match access-group 2001
class-map match-all default
fair que
policy-map QOS
  class IPSEC
  Set ip precedence 4
  police rate percentage  30 conform-action transmit exceed-action set-prec-transmit 0
  class FTP
  Set ip precedence 4
  police rate 20  conform-action transmit exceed-action set-prec-transmit 0
  class default
    fair-queue
ip access-list extended IPSEC-DATA
permit esp any any
permit udp any eq isakmp any eq isakmp
service-policy output QOS
Thanks in advance for quick reply...
Anish
Mahesh Gohil
Level 7
Level 7
Hello Anish,
I think class-default is generated by default and you do not need to configure it
try to see class-default at last in output of sh policy-map interface
if not you can remove below lines from config
class default
    fair-queue
and add
class class-default
and see if traffic matches in this
Hope this helps
Mahesh
Thanks mahesh for your quick reply ,today  I will check it and update yisou. Second thing what will be the impact of below command while traffic crossing 30%.
Anish
Hello Anish,
as you set above statement the exceed traffic will be carry forwarded to class-default
hope this helps
mahesh
HI Mahesh,
  Today I have tried with the below config ....But still no traffic is going through the default class...Pls find the output of show policy int command also..
policy-map TEST
       class IPSEC
              set precedence 4
       class FTP
              set precedence 3
       class class-default
permit esp any any
access-list 2001 permit ip 172.16.16.0 0.0.0.255 any
Router#sh run int Gi2/5
Building configuration...
Current configuration : 236 bytes
interface GigabitEthernet2/5
bandwidth 74516
ip address 1.x.x.x 255.255.255.252
speed 100
duplex full
no snmp trap link-status
no keepalive
no cdp enable
service-policy output TEST
end
Router#
***************************** Output *************************
Router#sh policy-map  int Gi2/5
GigabitEthernet2/5
  Service-policy output: TEST
    class-map: IPSEC (match-any)
      Match: access-group name IPSEC-DATA
      set precedence 4:
      Earl in slot 5 :
        27934360 bytes
        5 minute offered rate 632024 bps
        aggregate-forwarded 27934360 bytes
    class-map: FTP (match-all)
      Match: access-group 2001
      set precedence 3:
      Earl in slot 5 :
        155917 bytes
        5 minute offered rate 3664 bps
        aggregate-forwarded 155917 bytes
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
Router#
Router#
GigabitEthernet2/5
      set precedence 4:
      Earl in slot 5 :
        33400816 bytes
        5 minute offered rate 735152 bps
        aggregate-forwarded 33400816 bytes
      set precedence 3:
      Earl in slot 5 :
        181727 bytes
        5 minute offered rate 4128 bps
        aggregate-forwarded 181727 bytes
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
Anish
