QOS Input policy
May I know what is the config for service-policy input?
I want to applied QOS output and input on the voice gateway/router. We monitored the Polycom and router both input and output. These are the configurattions we have made:
class-map match-any NetMeeting
match access-group name NetMeeting
class-map match-any CONTROL
match  precedence 3
match access-group name SIGNALING
class-map match-any VIDEO
match  precedence 4
match access-group name NETMEETING
class-map match-any VOICE
match access-group name VOICE
class-map match-any AUDIO
match  precedence 5
policy-map QOS
class VOICE
  priority percent 10
class VIDEO
  bandwidth percent 50
class AUDIO
  priority percent 4
class CONTROL
  bandwidth percent 3
class class-default
  fair-queue
  random-detect
interface Serial0/0/0
description <<<<< TO MPLS-IPVPN LINK >>>>>
bandwidth 2048
no ip address
ip flow ingress
encapsulation frame-relay IETF
frame-relay lmi-type ansi
service-policy output QOS
*We have no packet loss % in transmit but receiving has.
When I am applying these configurations:
interface GigabitEthernet0/0
description <<<<<to Switch LAN going to Polycom>>>>>
ip address 192.168.4.1 255.255.255.0
ip flow ingress
duplex auto
speed auto
service-policy input QOS <--------- * I want to applied also QOS for the incoming packets to polycom. But failed.
result: low latency queuing feature not supported input policy
may I know if there is something wrong to the config of policy-map for Input? I have search for the input policy that priority/bandwidth is not supported for this policy. Is this correct? If yes, may I know how will I configure the input policy?
Highly appreciated for your immediate assistance.
Thank you very much!
Ralph
John Blakley
Ralph,
I usually use input for marking/policing traffic. Do you control the other side as well? I'm assuming so....
Have you applied the same policy to both ends outbound facing the wan? Can you post "show policy-map interface s0/0/0"?
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi John,
Here is the show policy-map int s0/0/0:
Serial0/0/0
  Service-policy output: QOS
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
    Class-map: VOICE (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name VOICE
        0 packets, 0 bytes
        5 minute rate 0 bps
      Priority: 10% (204 kbps), burst bytes 5100, b/w exceed drops: 0
    Class-map: VIDEO (match-any)
      24299 packets, 9062752 bytes
      5 minute offered rate 199000 bps, drop rate 0 bps
      Match:  precedence 4
        0 packets, 0 bytes
                5 minute rate 0 bps
      Match: access-group name NETMEETING
        5 minute rate 199000 bps
      Queueing
      (pkts output/bytes output) 24299/9062584
      bandwidth 50% (1024 kbps)
    Class-map: AUDIO (match-any)
      0 packets, 0 bytes
      Match:  precedence 5
        0 packets, 0 bytes
        5 minute rate 0 bps
      Priority: 4% (81 kbps), burst bytes 2000, b/w exceed drops: 0
    Class-map: CONTROL (match-any)
      616 packets, 169436 bytes
      5 minute offered rate 9000 bps, drop rate 0 bps
      Match:  precedence 3
        0 packets, 0 bytes
                       5 minute rate 0 bps
      Match: access-group name SIGNALING
        5 minute rate 9000 bps
      Queueing
      (pkts output/bytes output) 616/169436
      bandwidth 3% (61 kbps)
    Class-map: class-default (match-any)
      36844 packets, 10444109 bytes
      5 minute offered rate 243000 bps, drop rate 0 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
      (pkts output/bytes output) 36849/10445401
      Fair-queue: per-flow queue limit 16
        Exp-weight-constant: 9 (1/512)
        Mean queue depth: 1 packets
        class     Transmitted       Random drop      Tail/Flow drop Minimum Maximum Mark
                  pkts/bytes    pkts/bytes       pkts/bytes    thresh  thresh  prob
        0           36412/10382489        0/0              0/0                 20            40  1/10
        1               0/0               0/0              0/0                 22            40  1/10
        2               0/0               0/0              0/0                 24            40  1/10
        3               0/0               0/0              0/0                 26            40  1/10
        4               0/0               0/0              0/0                 28            40  1/10
        5               0/0               0/0              0/0                 30            40  1/10
        6             437/62912           0/0              0/0                 32            40  1/10
        7               0/0               0/0              0/0                 34            40  1/10
I applied also service-policy output QOS on the other side router facing the WAN with 100Mbps BW.
thanks for your reply
Best regards,
Ralph
Ralph,
What's the issue? I don't see any drops on any of these classes....Have you cleared counters recently?
John
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Inbound policies cannot contain any queuing type classes.  I.e. your classes are restricted in supported commands.
