09-13-2013 04:54 PM - edited 03-04-2019 09:02 PM
Need Some Help,
I configured DSCP marking on my 3750E, however i am not seeing any hits on the correct class. Here is my config.
Class Map match-any TEST
Match access-group name TEST
Match ip dscp ef (46)
Policy Map TEST
Class TEST
set dscp ef
police 128000 bps 8000 byte conform-action transmit exceed-action policed-dscp-transmit
Extended IP access list TEST
10 permit udp any range 49152 57500 any
20 permit udp any any range 49152 57500
interface GigabitEthernet1/0/24
service-policy input TEST
I verified with WireShark that the traffic coming from my application is using a UDP port in the range 49152 57500, however i am not seeing any matches on the right class, the traffic is matching only the default Class:
Clgr-ct18-sw7(config-cmap)#do sh mls qos int GigabitEthernet1/0/24 st
GigabitEthernet1/0/24 (All statistics are in packets)
dscp: incoming
0 - 4 : 1493 0 0 0 0 <<<<<<<<<<<<<<
40 - 44 : 0 0 0 0 0 <<<<<<<<<<<<<<<<<< No Matches on 46
Any help/advise is highly appreciated!
A
09-13-2013 05:12 PM
Hi Amir,
Do 'show mls QoS int sta' on the outgoing interface, see if the packet is marked to EF.
HTH,
Lei Tian
09-13-2013 05:41 PM
Both the incoming and ongoing interfaces show zero counts on the EF. Am i missing something on config? I have the feelnig that i am not matching traffic.
Thoughts?
09-13-2013 06:12 PM
How's config look like on the outgoing interface? Is mls QoS enabled globally?
HTH,
Lei Tian
09-13-2013 06:24 PM
Mls is golablly enabled.
Which interface are you referring by outgoing interface? The Trunk? If you are asking about the Trunk interface then all what i am doing there is trust DSCP
Here is setup i have:
PC--->Phone---Switch----Core Switch
09-13-2013 06:43 PM
Yeah, probably is your trunk. So you check the show mls QoS sta on the trunk interface, and no packet in EF?
HTH,
Lei Tian
09-15-2013 01:37 PM
I will test this and get to you back..
09-19-2013 09:07 AM
Sorry for the delay here is the output from the trunk, i don't see any EF traffic there too, what are your thoughts?
GigabitEthernet1/0/1 (All statistics are in packets)
dscp: incoming
0 - 4 : 42592 0 0 0 1355
20 - 24 : 0 0 0 0 27
45 - 49 : 0 0 0 50 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 6219 0 0 0 0
5 - 9 : 0 0 0 73 0
45 - 49 : 0 0 0 604 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 44494 0 0 0 0
5 - 7 : 2 113 1004
cos: outgoing
0 - 4 : 6223 73 0 0 0
5 - 7 : 0 604 9349
output queues enqueued:
queue: threshold1 threshold2 threshold3
queue 0: 0 0 0
queue 1: 0 165 9953
queue 2: 0 0 6050
queue 3: 73 0 8
output queues dropped:
queue 0: 0 0 0
queue 1: 0 0 0
queue 2: 0 0 0
queue 3: 0 0 0
Policer: Inprofile: 0 OutofProfile: 0
