QoS / Microbursts
joneswill
Can anyone point me to cisco qos documentation specific to microbursts?
I would like to create a qos policy for certain multicast traffic that, by its nature, microbursts quite frequently, up to 1Gb/s.  Whilst I have 1Gb wan links, I want to make sure that I give the multicast traffic a guaranteed amount of bandwidth, but that the qos profile takes into account the burstiness (on a millisecond basis) of the traffic.
any pointers would be great.
thanks
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Unless you're dealing with shapers or policers, you wouldn't normally concern your self with millisecond burstiness.
If your multicast traffic isn't particularly time sensitive, you would only need to insure your QoS policy provides enough bandwidth to satisfy the expected load with enough queue depth to handle bursts.  If your multicast traffic is time sensitive, then you need to insure you can prioritize a burst so that it is not much queued, e.g. LLQ in CBWFQ.
