QOS Not matching voice traffic
emphillips00
Hey all,
I have the following policy map on the outbound direction of my MPLS interface. The purpose is to give a priority queue for voice, and to make traffic to our ERP system the next highest priority. However, we are getting garbled voice quality. I did a "show policy-map int multilink 2" and it is showing 0 voice packets, but lots of ERP packets.
Am I correct assuming the attached output means no packets are getting into that priority queue? And any thoughts why? I followed ShoreTel's guide, and either DSCP EF, or the access-list method will work.
class-map match-any badtraffic
match protocol gnutella
match protocol kazaa2
class-map match-any email
match access-group name ACLemail
class-map match-any qad
match access-group name ACLqad
match access-group name ACLimportant
class-map match-any voice
match dscp ef
policy-map pmap_mpls
class voice
priority 512
class qad
set dscp af21
bandwidth remaining percent 50
class email
set dscp af11
bandwidth remaining percent 25
class badtraffic
set dscp default
bandwidth remaining percent 1
class class-default
set dscp default
bandwidth remaining percent 24
random-detect dscp-based
Service-policy output: pmap_mpls
Class-map: voice (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name ACL_shoretel_voice
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 512 (kbps) Burst 12800 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: qad (match-any)
18668 packets, 1369565 bytes
Match: access-group name ACLqad
7580 packets, 704662 bytes
5 minute rate 0 bps
Match: access-group name ACLimportant
11088 packets, 664903 bytes
5 minute rate 0 bps
QoS Set
dscp af21
Packets marked 18454
Queueing
Output Queue: Conversation 265
Bandwidth remaining 50 (%)Max Threshold 64 (packets)
(pkts matched/bytes matched) 15195/1179721
(depth/total drops/no-buffer drops) 0/0/0
7 Replies 7
michaelchoo
I noticed that you presume the voice packets have been marked with DSCP EF. How is your switch configured? Do you have appropriate DSCP-to-CoS mapping and CoS-to-DSCP mapping? Assuming you use Cisco Catalyst switch, make sure you use AutoQoS to configure the switch QoS, then fine-tune the configurations to include your ERP, email, and P2P traffic.
ariesc_33
im not sure but you may need to define RTP on your class map for voice.
ariesc_33
im not sure but you might need to define RTP on your class map for voice.
Pavel Bykov
Level 5
Level 5
Correct your configuration with the following commands:
match protocol rtp audio
Hope this helps.
Please rate all helpful posts.
Hey guys,
I have a message off to the phone installers to verify how they are marking packets on the phones.
In the mean time I have added rtp audio to the class.
I will definitely update this post once I find out what the issue is.
Thanks a bunch for everyone's prompt replies.
-Eric
Cisco phones automatically mark voice as EF.
Then switches need:
1. mls qos enable
2. on each port: mls qos trust dscp and mls qos trust device cisco-phone (or similar)
3. On trunks: mls qos trust dscp
Otherwise all marking will automatically be remarked to 0 (default).
cfolkerts
This is a Shoretel phone system so it would be tough to match the protocol if Cisco is unaware or does not have their protocol in NBAR.
I would reference the Shoretel docs to find out which udp ports they use for voice. Then I would use an access-list to define the traffic. Or if the IP phones mark the traffic, I would configure on your edge switches mls qos trust cos and apply the appropriate COS-DSCP mapping.
As a side note, since you are utilizing PPP multilink I would suggest implementing the following commands to the configuration as well.
Under the multilink int
R1(config-if)#ppp multilink fragment delay 10
R1(config-if)#ppp multilink interleave
