QOS on 4500 Switch
Desmond Smith
I am looking to enable QOS on a 4500 Switch with the following specifications:
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.04.00.SG RELEASE SOFTWARE (fc3) /with Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT1639L46S
I have configured QOS on the 3750 switches but this seems to be a bit different. Can anyone shed a bit of light on the subject.
Another quick question when you enable QOS globally on a device does it automatically create the ingress and egress queues and the SRR information?
Thanks in advance,
Desmond
Hello
Please review the cco doc for 4500 qos
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/54sg/configuration/guide/qos.html
Regards your query about ingress/regress queues and SRR- nothing suggests this occurs when you globally enable qos
Res
Pul
Kind Regards
Paul
