QoS on 7600 series router
ayokunles
I am looking for the best QoS method for a 7600 series router.
We have a 7604 edge router that has remote branch connections to it via GRE tunnels.
unfortunately I cannot shape on these GRE tunnels neither can I use bandwidth or priority statements.
I would appreciate the best QoS technique to use as policing is an extreme measure.
thanks guys.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
The "best" QoS for a 7600 would require hardware that "best" supports QoS features; often found in WAN oriented line cards.  FlexWANs support a rich QoS feature set, believe the SIP-200/400s do too.
Another "best" QoS approach for a 7600 is to not use the 7600, but perhaps front-end it with a more feature rich WAN router.  Depending on how much bandwidth you're supporting for these tunnels, it may actually be more cost effective than some of the 7600 WAN type line cards.
Indeed some "extreme" QoS can be implemented with policing, but IMO it's like Civil War surgery, i.e. amputating a limb to save a life.  So, recommend consideration of the above before going with policing solutions.
