QOS on ATM-pvc with 15.x IOS
HUBERT RESCH
Level 3
Level 3
Hi have a question about QOS on ATM PVC
pre 12.4.20T we did it like following, as I understood we do not need a shaper in the service-policy, shaping/policing should be configured with atm vc-class, correct.
vc-class atm 32000Kbps-PVC
  vbr-nrt 32000 32000 1 32000 32000 1
  tx-ring-limit 3
  oam-pvc manage
  encapsulation aal5snap
policy-map xQOS-QUEUE-POLICY
class xQOS-CLASS-EF_Realtime_Voice
    priority percent 20
class xQOS-CLASS-CS5
class xQOS-CLASS-AF41
    bandwidth remaining percent 10
class xQOS-CLASS-CS4_Realtime_Video
    bandwidth remaining percent 40
class xQOS-CLASS-AF31_Video_Streaming
    bandwidth remaining percent 8
class xQOS-CLASS-CS3_Realtime_Signalling
    bandwidth remaining percent 3
class xQOS-CLASS-AF21_Transactional_Data
class xQOS-CLASS-CS2_Management_OAM
class xQOS-CLASS-AF11_Bulk_Data
    bandwidth remaining percent 5
  class xQOS-CLASS-CS1_Scavanger_Data
class xQOS-CLASS-BE_Best_Effort
    bandwidth remaining percent 19
interface ATM1/0
description ATM-OC3
no ip address
ip flow ingress
logging event subif-link-status
load-interval 30
no atm ilmi-keepalive
no atm enable-ilmi-trap
max-reserved-bandwidth 100
hold-queue 200 in
interface ATM1/0.12 point-to-point
description 32Mbit/s-ATM-PVC
mtu 1578
bandwidth 32000
ip address 22.161.198.102 255.255.255.252
ip accounting output-packets
ip flow ingress
ip pim sparse-mode
delay 200
pvc PVC 12/161
  class-vc 32000Kbps-PVC
  service-policy output xQOS-QUEUE-POLICY
upgrading to 15.0 we had a lot of drops though there was less traffic,
  Service-policy output: xQOS-QUEUE-POLICY
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
    Class-map: xQOS-CLASS-EF_Realtime_Voice (match-any)
      0 packets, 0 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
        0 packets, 0 bytes
        30 second rate 0 bps
      Priority: 20% (6400 kbps), burst bytes 160000, b/w exceed drops: 0
    Class-map: xQOS-CLASS-CS5 (match-any)
      0 packets, 0 bytes
      Match: ip dscp cs5 (40)
        0 packets, 0 bytes
    Class-map: xQOS-CLASS-AF41 (match-any)
      30 packets, 1863 bytes
      Match: ip dscp af41 (34) af42 (36) af43 (38)
      Queueing
      (pkts output/bytes output) 30/1863
      bandwidth remaining 10% (2560 kbps)
    Class-map: xQOS-CLASS-CS4_Realtime_Video (match-any)
      0 packets, 0 bytes
      Match: ip dscp cs4 (32)
        0 packets, 0 bytes
      Queueing
      bandwidth remaining 40% (10240 kbps)
    Class-map: xQOS-CLASS-AF31_Video_Streaming (match-any)
      0 packets, 0 bytes
      Match: ip dscp af31 (26) af32 (28) af33 (30)
        0 packets, 0 bytes
      Queueing
      bandwidth remaining 8% (2048 kbps)
    Class-map: xQOS-CLASS-CS3_Realtime_Signalling (match-any)
      42239 packets, 3828404 bytes
      30 second offered rate 458000 bps, drop rate 288000 bps
      Match: ip dscp cs3 (24)
        30 second rate 458000 bps
      Queueing
      (queue depth/total drops/no-buffer drops) 64/23698/0
      (pkts output/bytes output) 18541/1473065
      bandwidth remaining 3% (768 kbps)
    Class-map: xQOS-CLASS-AF21_Transactional_Data (match-any)
      2618 packets, 479056 bytes
      30 second offered rate 51000 bps, drop rate 0 bps
      Match: ip dscp af21 (18) af22 (20) af23 (22)
        30 second rate 51000 bps
      Queueing
      (queue depth/total drops/no-buffer drops) 15/0/0
      (pkts output/bytes output) 2618/479056
    Class-map: xQOS-CLASS-CS2_Management_OAM (match-any)
      12008 packets, 12324882 bytes
      30 second offered rate 1188000 bps, drop rate 662000 bps
      Match: ip dscp cs2 (16)
        30 second rate 1188000 bps
      Queueing
      (queue depth/total drops/no-buffer drops) 22/5047/0
      (pkts output/bytes output) 6961/6358429
    Class-map: xQOS-CLASS-AF11_Bulk_Data (match-any)
      23469 packets, 4343590 bytes
      30 second offered rate 342000 bps, drop rate 69000 bps
      Match: ip dscp af11 (10) af12 (12) af13 (14)
        30 second rate 342000 bps
      Queueing
      (queue depth/total drops/no-buffer drops) 62/5585/0
      (pkts output/bytes output) 17884/3687620
      bandwidth remaining 5% (1280 kbps)
    Class-map: xQOS-CLASS-CS1_Scavanger_Data (match-any)
      33 packets, 2124 bytes
      Match: ip dscp cs1 (8)
      Queueing
      (pkts output/bytes output) 33/2124
      bandwidth remaining 1% (256 kbps)
    Class-map: xQOS-CLASS-BE_Best_Effort (match-any)
      45222 packets, 6439836 bytes
      30 second offered rate 614000 bps, drop rate 251000 bps
      Match: ip dscp default (0)
        30 second rate 614000 bps
      Queueing
      (queue depth/total drops/no-buffer drops) 64/17640/0
      (pkts output/bytes output) 27582/3986130
      bandwidth remaining 19% (4864 kbps)
    Class-map: class-default (match-any)
      156 packets, 45864 bytes
      Match: any
      (pkts output/bytes output) 180/47732
seems the queue-depht MUST be increased.
Is that all what has changed or do I need a shaper also under the service-policy like following , I am really not sure?
  tx-ring-limit 3
  oam-pvc manage
    priority percent 20
    queue-limit 256 packets
policy-map xQOS-SHAPED-QUEUE-POLICY
class class-default
shape average 32000000 32000 0
  service-policy xQOS-QUEUE-POLICY
interface ATM1/0
description ATM-OC3
no ip address
ip flow ingress
load-interval 30
hold-queue 200 in
mtu 1578
bandwidth 32000
ip flow ingress
ip pim sparse-mode
delay 200
pvc PVC 12/161
  service-policy output xQOS-SHAPED-QUEUE-POLICY
Thx in advance
Hubert
paolo bevilacqua
You should not need a shaper.
But if you find that the ATM native shaping is not working, you may need that as a workaround while waiting for cisco to recognise and fix the bug (may take a long time however you are helped by having it working with an older IOS version).
