QoS on Cisco 4948 switch
SUNIL Perumana
Dear All,
Can somebody tell me how to configure QoS on Cisco 4948. I have three VLans in my network. First is video traffic second is the voice traffic and third is the data traffic . I need to set the priority in QoS in the following way
i.e. Video traffic -  1st pref
     Voice traffic -  2nd pref
     Data traffic   -  3rd pref
Please let me know how to configure for this requirement.
Sunil P
SUNIL Perumana
Dear All,
I would like to know how to do bandwidth management for the three types of traffic
1) Video 1st priority
2) Voice 2nd priority
3) Data 3rd priority
Sunil P
I have mentioned below some useful links for configuring Qos.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/54sg/configuration/guide/qos.pdf
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfintro.html
Hope this helps
Cheers
Somu
Rate this answer if you find the content was helpful
I have mentioned below the configurations for your requirement.
ip cef
class-map match-all voice
match ip dscp ef
class-map match-all Interactive video
match ip dscp af41 af42
class-map match-any call signaling
match ip dscp cs3
match ip dscp af31
class-map match-all Routing
match ip dscp cs6
Class-map match-all Net Mgmt
match ip dscp cs2
class-map match-all Mission-critical
match ip dscp 25
class-map match transactional Data
match ip dscp af21 af 22
class-map match-all bulk data
match ip dscp af11 af12
class-map match-all streaming video
match ip dscp cs4
class-map match-all Scavenger
match ip dscp cs1
policymap SUNIL_TEST
class voice
priority percent 18
class interactive Video
priority percent 15
class call signaling
bandwidth percent 5
class routing
bandwidth percent 3
class Net Mgmt
bandwidth percent 2
class Mission-Critical data
bandwidth percent 10
random-detect
class Transactional Data
bandwidth percent 7
random-detect dscp-based
class Bulk Data
bandwidth percent 4
random-detect dscp based
class streaming video
class scavenger
bandwidth percent 1
class class-default
bandwidth percent 25
random-detect
Apply the policy map under the specific interface. kindly note that one policy per direction.
Hope this helps
Cheers
Somu
Pls rate this answer if the content found was useful
