QOS on local router and on ISP MPLS
shirwaziri1_2
ISP has qos configured on their MPLS a certain way. My clients has thier router's QOS configured another. ISP says that QOS settings need to match on both mpls and local router. a certain tech from a certain company told me that the ISP has QOS configured for outbound qos only. There for the qos that is setup on the local router is it's own qos.
He said, as long as thier is no complaints then everything is fine the way it is setup. The only thing he suggested was increasing the bandwight by 10% on the video priority que.
ROCH#show policy-map int serial 0/0
Serial0/0
Service-policy output: Wan-Edge
Class-map: Voice (match-all)
62587286 packets, 12744154599 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: access-group 103
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 30 (%)
Bandwidth 463 (kbps) Burst 11575 (Bytes)
(pkts matched/bytes matched) 7086898/1442388078
(total drops/bytes drops) 0/0
Class-map: Voice-Control (match-all)
1216856 packets, 101813718 bytes
Match: access-group 104
Queueing
Output Queue: Conversation 265
Bandwidth 2 (%)
Bandwidth 30 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 519244/68492814
(depth/total drops/no-buffer drops) 0/0/0
Class-map: video (match-all)
1701 packets, 817409 bytes
Match: access-group 105
Queueing
Strict Priority
Bandwidth 40 (%)
Bandwidth 617 (kbps) Burst 30000 (Bytes)
(pkts matched/bytes matched) 351/368417
(total drops/bytes drops) 29/41515
Class-map: class-default (match-any)
381202920 packets, 77493095931 bytes
30 second offered rate 370000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/35159/0
Roch#
Hope i did not confuse too much but any assistance will be appreciated.
royalblues
Level 10
Level 10
Yes its somewhat true that the QoS setings should match on both the sides.
Whatever markings you do should be trusted by the service provider, otherwise your important traffic may not be given the correct priority in the SP's MPLS cloud
Narayan
