QoS on multiple sub-interfaces at HQ site
aoshea
Dear Support,
Many thanks for everyone’s assistance so far but have a final question to complete my QoS configuration.
Q. I have a double hub-and-spoke topology, that is redundant. Each remote site has a connection to both the datacentre and the HQ site. At both the HQ and Datacentre sites, they are connected to the remote sites via a LES 10 connection that has 6 sub-interfaces. Each remote site has bandwidth of 2Mbps.
If I have a single Ethernet interface (LES 10), that has several sub-interfaces how should I set the ‘shape’ parameter or do I need several ‘shapers’ (i.e. do i need a separate policy-map for each sub-interface or can it been done with a single one?)
i.e.
class-map match-all BULK-DATA
match ip dscp af11 af12
class-map match-all INTERACTIVE-VIDEO
match ip dscp af41 af42
class-map match-all VOICE
match ip dscp cs5
class-map match-all MISSION-CRITICAL-DATA
match ip dscp 25
class-map match-all ROUTING
match ip dscp cs6
class-map match-all SCAVENGER
match ip dscp cs1
class-map match-all NET-MGMT
match ip dscp cs2
class-map match-any CALL-SIGNALING
match ip dscp cs3
match ip dscp af31
class-map match-all TRANSACTIONAL-DATA
match ip dscp af21 af22
policy-map BRANCH-WAN-EDGE
class VOICE
priority percent 50
class INTERACTIVE-VIDEO
priority percent 2
class CALL-SIGNALING
bandwidth percent 5
class ROUTING
bandwidth percent 3
class NET-MGMT
bandwidth percent 2
class MISSION-CRITICAL-DATA
bandwidth percent 5
random-detect
class TRANSACTIONAL-DATA
bandwidth percent 2
random-detect dscp-based
class BULK-DATA
bandwidth percent 2
class SCAVENGER
bandwidth percent 1
class class-default
bandwidth percent 3
random-detect
policy-map Shaper-sub-int1100
class class-default
shape average 1984000
service-policy BRANCH-WAN-EDGE
policy-map Shaper-sub-int1111
class class-default
policy-map Shaper-sub-int1113
class class-default
policy-map Shaper-sub-int1114
class class-default
policy-map Shaper-sub-int1115
class class-default
policy-map Shaper-sub-int1116
class class-default
interface FastEthernet1/0
speed 10
full-duplex
interface FastEthernet1/0.1100
service-policy output Shaper-sub-int1100
interface FastEthernet1/0.1111
service-policy output Shaper-sub-int1111
interface FastEthernet1/0.1113
service-policy output Shaper-sub-int1113
interface FastEthernet1/0.1114
service-policy output Shaper-sub-int1114
interface FastEthernet1/0.1115
service-policy output Shaper-sub-int1115
interface FastEthernet1/0.1116
service-policy output Shaper-sub-int1116
encapsulation dot1Q 1116
ip address 172.16.32.33 255.255.255.252
thanks again, regards Adrian.
pkhatri
Level 11
Level 11
Hi Adrian,
You do need a separate service-policy for each sub-interface as each of them needs to have a shaper applied individually which would result in back-pressure being applied in order to build up queuss and service them accordingly.
Also, if you are applying the same policy to each sub-interface and are confident that the shaping rates for all of them are always likely to be the same, you can use a single policy-map for all the interfaces. That is, instead of creating separate "Shaper-sub-intxxx" policies, just create a single one and apply it to all the sub-interfaces individually.
Cheers,
Paresh.
pkhatri
Level 11
Level 11
Hi Adrian,
Cheers,
Paresh.
Hi.
I have the same setup.
My problem is, I can attached a policy on one sub-interface. But I cant on another sub-interface.
Example:
Gi4/0/3.1500 - I cant attach the policy-map
Gi4/0/3.1510 - I can attahc the same policy-map..
Im using 7200 NPE-G1 built-in GE interface and 7600 SIP-600 WAN card.
comments on this?
