QOS on tunnel interface
carl_townshend
Hi all
I have applied qos for my gre tunnel, I have applied the qos ont he physical interface and put qos pre classify on the tunnel, however I have done a show plicy map interface command and its not seeing any traffic matching the policy
any ideas why this is ?
cheers
Carl
7 Replies 7
Helo
Can you post your configuration
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
class-map match-any VIDEO-CONFERENCE
match protocol rtp
match protocol h323
match access-group name video-conference-devices
policy-map VIDEO-CONFERENCE
class VIDEO-CONFERENCE
    priority 2048 384000
interface FastEthernet0/0
description Intersite-Link
bandwidth 6000
ip address x.x.x.x
ip flow ingress
duplex auto
speed auto
service-policy output VIDEO-CONFERENCE
interface Tunnel10
description InterSite Link tunnel
bandwidth 6000
ip address x.x.x.x
ip flow ingress
ip tcp adjust-mss 1460
delay 100
qos pre-classify
keepalive 10 3
tunnel source x.x.x.x
tunnel destination x.x.x.x
Hello Carl,
Try this -
match protocol ip rtp 16384 16383
class class-default
fair-queue
priority 2048
policy-map QOS
class class-default
shape avaerage 6144000
policy VIDEO-CONFERENCE
interface Tunnel10
service-policy output QOS
res
Paul
Thanks.
Kind Regards
Paul
I see you have done a child policy, why is this ?
is this what we need to do to apply to tunnels ?
Hello
This way all traffic is shaped a 6mb but with 2mb alocated for LLQ, so when vioce is up LLQ will be serviced at 2mb no matter what and the rest will share the remaining 4mb for queuing via the class class-default.
res
Paul
Thanks.
Kind Regards
Paul
Do I still need to leave qos pre classify command on the tunnel interface ?
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
If you want to classify tunnel traffic, on the physical interface, beyond looking at the tunnel's header, you do.
For example, if you were only using ToS, as the encapsulation routinely copies it, you don't need pre-classify.
If you wanted to classify on the original (pre-tunnel) source or destination IP, then you need pre-classify.
BTW, some classification, such as some NBAR, will only work correctly on the tunnel, as such can look deeper into the packet.
