QOS over frame-relay with IPSEC and GRE
steve.kerr
I am attempting to cofigure QOS over a frame relay circuit which also uses GRE tunnels with IPSEC.
How can I show that the QOS profile is having the desired affect?
6 Replies 6
mheusinger
Level 10
Level 10
per RFC the TOS byte of the original IP header will be copied into the new IPSec header. So in an output policy you can f.e. match on IP precedence, if this has been set in the original packet.
A second option is to use "qos pre-classify" on the tunnel interface or crypto policy. This will keep a copy of the original header to be used for classification on the output interface.
A description of the options is given at "Configuring QoS for Virtual Private Networks"
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800c75d3.html
I am assuming you use MQC (class-map, policy-map, service-policy). Then you can execute
show policy-map MyMAP interface Serial0/0
which will tell you all the counters about IP packets treated by this policy. The counters are also available through SNMP (f.e. through QoS Policy Manager).
Hope this helps! Please rate all posts.
pkhatri
Level 11
Level 11
You should be able to use the 'show policy-map interface' command to see what the service policy is doing.
Also, when using tunnels, you should be careful about where you place the service-policy and whether you need to use qos-preclassify ...
Pls do remember to rate posts.
Paresh
Thanks for the response, but I have a question regarding the output below from one of my routers.
How is it determining the bandwidth? I have 2 PVC's on sub-interfaces s0/0.1 and s0/0.2, each has the command "bandwidth 32000" configured and yet the bandwidths indicated using the show command are wildley different?
Class-map: output-fos (match-any)
22112 packets, 2993222 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: ip precedence 2
5 minute rate 0 bps
Queueing
Output Queue: Conversation 265
Bandwidth 25 (%)
Bandwidth 386 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 3414/675064
(depth/total drops/no-buffer drops) 0/0/0
Class-map: output-atm (match-any)
173201 packets, 11967873 bytes
Match: ip precedence 1
5 minute rate 0 bps
Queueing
Output Queue: Conversation 266
Bandwidth 15 (%)
Bandwidth 231 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 5864/957600
Class-map: output-creditease (match-any)
0 packets, 0 bytes
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 267
Bandwidth 10 (%)
Bandwidth 154 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 0/0
This is the configuration that I am using:
class-map match-any input-fos
match access-group 152
class-map match-any input-atm
match access-group 153
class-map match-any output-creditease
match ip precedence 2
class-map match-any input-creditease
match access-group 154
class-map match-any output-fos
class-map match-any output-atm
match ip precedence 1
policy-map setToS
class input-fos
set precedence 2
class input-atm
set precedence 1
class input-creditease
set precedence 2
policy-map useToS
class output-fos
bandwidth percent 25
class output-atm
bandwidth percent 15
class output-creditease
bandwidth percent 10
policy-map use-tos
I have added the policies to interfaces as shown below:
interface FastEthernet0/0
description Harbour Front Branch LAN
ip address xxx.xxx.xxx.xxx 255.255.255.0
service-policy input setToS
ip route-cache flow
duplex auto
speed auto
(ip address removed for security reasons)
interface Serial0/0
no ip address
service-policy output useToS
encapsulation frame-relay IETF
cdp enable
frame-relay lmi-type q933a
int s0/0 configured as two sub-interfaces s0/0.1 and s0/0.2. s0/0.1 is the live interface, s0/0.2 connects to DR and passes no traffic in normal operation.
and I have used the qos pre-classify command on the crypto maps and the tunnels interfaces
the config for a single PVC should look like this:
interface Serial0/0
enc fram
frame-relay traffic-shaping
interface Serial0/0.1 point-to-point
ip address ...
frame-relay interface-dlci 100
class MyPVC
map-class frame-relay MyPVC
frame-relay cir 32000
service-policy output useTOS
(from the top of my head, so minor IOS inconsistencies might exist ;-)
This will allow you to get the proper bandwidth in the policies.
Regards, Martin
Martin,
how does this tie in with my GRE tunnel interfaces as all of my data goes down the tunnels, therefore all the serials interfaces and sub-interfaces will see is GRE with IPSEC 3DES on top?
Steve
Hi Martin,
Additionally, when I try to add the "frame-relay traffic-shaping" command to the s0/0 interface, I receive the following message:
Harbour_RTR01(config-if)#frame-relay traffic-shaping
Cannot set FCFS interface queueing.
Frame relay traffic-shaping not configured.
