04-10-2006 10:43 PM - edited 03-03-2019 12:22 PM
hi,
i have a channel attached 7513 router, which has the following interfaces inserted:
cisco RSP2 (R4700) processor with 131072K/2072K bytes of memory.
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Bridging software.
TN3270 Emulation software.
Chassis Interface.
1 CIP2 controller (2 IBM Channels).
3 VIP2 controllers (2 FastEthernet)(8 Ethernet)(8 Serial)(4 T1)(4 Token Ring).
8 Ethernet/IEEE 802.3 interface(s)
2 FastEthernet/IEEE 802.3 interface(s)
4 Token Ring/IEEE 802.5 interface(s)
8 Serial network interface(s)
2 IBM channel interface(s)
123K bytes of non-volatile configuration memory.
Slot 1:
Physical slot 1, ~physical slot 0xE, logical slot 1, CBus 0
Microcode Status 0x4
Master Enable, LED, WCS Loaded
Board is analyzed
Pending I/O Status: None
EEPROM format version 1
VIP2 controller, HW rev 2.10, board revision B0
Serial number: 08218518 Part number: 73-1684-04
Test history: 0x00 RMA number: 00-00-00
Flags: cisco 7000 board; 7500 compatible
EEPROM contents (hex):
0x20: 01 15 02 0A 00 7D 67 96 49 06 94 04 00 00 00 00
0x30: 58 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
Slot database information:
Flags: 0x4 Insertion time: 0x1DC4 (1y28w ago)
Controller Memory Size: 64 MBytes DRAM, 1024 KBytes SRAM
PA Bay 0 Information:
Mx Serial PA, 4 ports
HW rev 1.10, Board revision A0
Serial number: 08498829 Part number: 73-1577-05
PA Bay 1 Information:
Serial number: 09430051 Part number: 73-1577-05
now i have the task to remove the two 4-port Serial cards in slot 1.
is this hot removeable ??
or do i have to switch the router off ?
Solved! Go to Solution.
04-11-2006 02:35 AM
You can remove the board while the router is powered on. The board is hot swappable.It will not effect anything.
04-11-2006 02:35 AM
