QOS police issue and question
stoneystone
I have a star network with multiple l2l tunnels. I am trying to give priority to RDP (3389) traffic. The following is my config that I am trying to use:
hostname(config)#class-map RDP_Pri
hostname(config-cmap)#description "This class-map matches all RDP traffic for 1XX.XXX.XXX.XXX 1"
hostname(config-cmap)#match port tcp eq 3389
hostname(config-cmap)#match tunnel-group 1XX.XXX.XXX.XXX
hostname(config-cmap)#class-map RDP_BestEffort
hostname(config-cmap)#description "This class-map matches all best-effort traffic for 1XX.XXX.XXX.XXX"
hostname(config-cmap)#match flow ip destination-address
hostname(config-cmap)#policy-map QOS
hostname(config-pmap)#class RDP_Pri
hostname(config-pmap-c)#priority
hostname(config-pmap-c)#class RDP_BestEffort
hostname(config-pmap-c)#police output 200000 37500
hostname(config-pmap-c)#class class-default
hostname(config-pmap-c)#police output 1000000 37500
hostname(config-pmap-c)#service-policy QOS interface outside
hostname(config)#priority-queue outside
hostname(config-priority-queue)#queue-limit 2048
hostname(config-priority-queue)#tx-ring-limit 256
When I get to the command:
I get the following error message:
ERROR: Must deconfigure priority in this class before issuing this command
ERROR: tunnel-group can only be policed on a flow basis
Questions:
1. Why do I need to deconfigure priority? How would I do this?
2. Other than the errors, does this config look good? Can it be made better?
Laurent Aubert
I'm not an PIX/ASA expert but priority queue can't be policed so you have to choose. If you remove the policer, the second error message should also disappear.
If you want to keep the policer, you need the match flow ip destination-address command in the class-map.
Laurent.
